Temperature report push
Mats Even
Any one have an idea how I can make a scene that sends me a push or e-mail on a specific time with the temperature reading from one of my outdoor sensors?
4 answers to this question
Hi Mats,
Here i s a simple LUA-code to send tempdata a specified time.
Fill in your own ID and time.
  • Thanks. Works great. But what can I add to the code to send it just on e.g weekdays?
    @Mats Even,
    You can use Main scene for time based events control and solve all your problems with scheduled events. Having too many scenes looping all the time is not necessary and can use too much resources on your HC, but with this scene that is not necessary any more. You can start scenes, press buttons on VDs or change global variables values at specified time on selected days of the week. Check it out:
    Above code you can change to be like this:
    So it is still a scene and for example has ID = 28. You setup Main scene to run above scene like this:
    Above settings will send you temperature report only on weekdays at 14:00h and 19:00h!
