Migration Guide HCL to HC2
francisco
As I was previously by Fibaro support migration MAY be supported when cloud backup on HC2 will be avaliable. Are there any updates on this (the question to Fibaro team)?
  • 1 month later...
I just got my HC2 and it did not ocur to mi in the wildest dreams that there is no easy way to migrate from the HCL. Excluding and re-including all sensors and relays is going to be a royal pain in the neck. Seriously, Fibaro?  I though the "synchronize gateway" could be a way to do it but it is just a way to soft-link the two HC's, isn't it? What a disappointment. :(
  • 1 year later...
Hi Fibaro,
I'm getting mad of the memory issue with the HCL (even with 4.530) and thinking about a migration from HCL to HC2.
Have you made in the meantime some progress with the migration process ?
' Migration from HCL to HC2 is simply not supported, yet. '
If I have to reconfigure all devices (approx 50) it would be the same effort for me to switch to an other brand.
Thanks in advance for your replay
Liun
