How to make a scene to centralize a function
robmac
This technique can be used for a lot more but this simple case illustrates it in a very simple way.
I am not seeing a lot of example of using this feature posted so I thought this might give  a few who do not know some ideas. The technique is based around that second parameter of the fibaro:startScene method fibaro:startScene(sceneID,args).
args is a LUA table so you can pass pretty much anything to a scene via the API or from another piece of LUA. In this example only a table with one text element is passed.
Create a scene myDebugIllustration
You may need to set the number of instances to a larger number wen you use this properly.
Now create another scene myTestScene
Now remember that as I said earlier "a lua table can hold pretty much anything"
Enjoy
What if you send a function in the table? At work so I can't test but too curious ;-)
(guess they neuter it with a json.encode/decode ?)
Hi @robmac,
Thank you very much for sharing this feature. I wonder why this is still not documented on Fibaro developer site?! My HC2 is on 4.110 and this work nicely! This feature is exactly what I need for several solutions among which one is for sending messages! No more need for global variables.
@AutoFrank needs to see this for his Smart Message Hub solution !!
2 minutes ago, Sankotronic said:
Hi @robmac,
@robmac
@Sankotronic
Thanks for sharing this, I have been wondering if this was possible for a while now for simple functions such as url encode and other string sub functions
The most obvious use for SMH would be store/execute the SendMsgH function in a global instead of having to include in each scene
I must play around with this and see what may be achievable and see if its better than the use of GV
the list gets longer and the time available stays the same, need to prioritise better ;-)
    I am sure it will work. It is a LUA table so as long as the implementation is not mad there will be no issue.
    @robmac
    now I know what I'll be doing after dinner this evening :-)
    my wife will be delighted, she'll have the TV to herself this evening .....
    thanks
    I'm already implementing this feature to SMsgH and one of my scenes that are sending push and popup messages to help Frank :)
    @Sankotronic
    way ahead of me :-)
    thanks
  • Just remember they are making a copy of the table not passing a reference. You can not return data to the original instance of the  calling scene as far as I know.
    You could potentially chain it by killing the original instance of the calling scene and starting a new instance potentially. Just fork the code by checking for args.
    Thanks @robmac, I feel we should be okay, I'm thinking we can pass the string (json table) to the message hub scene from the scene that wants to use the message hub and process it within the message hub scene itself. Is this what you're thinking as well @Sankotronic ?
  • you know about fibaro:debug(urlencode('this is a string'))
    @robmacYou're full of gems this morning :-), tell me more
    @robmac I would be surprised if it worked. I thought they spawn new instances of the LUA engine (or LUA context) for each scene instance. I would suspect that the json'ed the arg and hand it over to the new instance.
    Haven't tested this code but something like this would be a way to get a return argument back (ok, with a global var). Not for rapid calls, but for larger library functions...
    Well as my quick experiment shows this doesn't work:
    but this does work:
    and what about
     split(text, delimiter)
    @robmac
    well, now you're just teasing :mrgreen:,
    Where have you hidden the fibaro fountain of knowledge ?, can us mere mortals gain access ?
    but this does work:
    @Sankotronic
    That's what I was thinking, except without the function in #2
    Could we get away with not wrapping it in a function is we wanted
    I assume it would work just as well ?
    This will be slick . a simple startScene to send the message to the hub.. :-D....
    alas as they refuse to allow loadtext they have blocked it. What a pity a small change to line 93 and the reconstituting code and I would think it could be done easily. Probably think it is a 'security risk':roll:
    but I know a way around it anyway:mrgreen:
    Edited by robmac
    2 minutes ago, AutoFrank said:
    @Sankotronic
    Well this syntax is working:
    Of course it doesn't have to be wrapped in function I'm just doing a quick test using your SendMsg function :)
    Next step is to change code of SMsgH scene.
    @Sankotronic
    Really starting to gather legs at this stage .... :-)
    ...  thx
    Is it possible to pass to a scene special characters like ä,ö,ü, ł, ó, ą ?
    Actually I get different chararacters: ÄÅÄÅÅ
