I'm looking for a simple thermostat function. I have a Fibaro Motion sensor for measuring temperature and I have electrical heating connected to a Switch relay.
I have created a heating panel, but this needs to be connected to a thermostat which I don't have.
Now I have seen that there was a function "Linking Devices" for heating, but this function isn't there in 4.110. It is replaced with associations, but this is not the solution.
Can somebody help me please?
Yannick
Yannick
Linked devices are still there. Just go to Panels -> Linked devices. It is at very bottom of the page. If you have HC2, then above VoIP panel.
There you can create linked device, but you have to add it in correct room.
Edited by jakub.jezek
  • Thanks Jakub. Looked completely over it.
    Is there a way to have the thermostat controller (daily calendar), like the heating panel, on the app? I have a fixed Android touchscreen on the wall and uses that to control the entire house.
