[VD] Sonos Players Status {v1.0} - 3 step setup.
If you are using the sonos-api then you may find this very easy to use VD helpful
It will display the status and volume of each player as well as a house summary of how many are active
The VD below is setup for two zones and is very easy to expand.
Three Step setup :-D
1) Import the VD, amend the IP address for your sonos-api device (port should be fine)  and save
2) Add extra players to the table at line 10 (keep name the same as your sonos player/zone name)
3) Add extra labels for each extra player/zone and save. (keep default label format which is Label3, Label4, etc)
Enjoy !!
-f
FILES
Sonos Players Status {v1.0} ----------------------------->
Edited by AutoFrank
14 answers to this question
interessting idea!
You have also to enter IPAdress and Port at the first tab of VD, or?
The debug said:
[ERROR] 20:27:40: line 20: attempt to concatenate field 'volume' (a nil value)
Regrads Hoggle
    2 minutes ago, Hoggle said:
    interessting idea!
    Regrads Hoggle
    @Hoggle
    ... oops :oops:.. yes, amend the ip address,port should be good
    sorry about that
    first post amended, suppose its 3 1/2 steps :mrgreen:
    Sorry, one Sonos was offline....
    Therefore the error.
    @Hoggle
    error on both sides so ;-)
    First post amended to help ...
    any use to you  ?
    Edited by AutoFrank
    Yes.
    I think, I need  an  Offline-Status.
    @Hoggle
    I got this message : [ERROR] 22:19:18: line 15: Expected value but found T_END at character 1
    Besides that I think I'm not 100% sure what IP adres you are referring to with "sonos-api device" is that one (any) of my Sonos devices ?
    note:
    This is my line 10: players = {"1) LivingRoom", "2) Dining Room", "3) Office", "4)Bathroom", "5 dressroom"}
    Edited by Patrick
    note:
    @Patrick
    The IP address i'm referring to is for the device that is hosting your sonos-api ( raspberry pi ??)
    The format of the table at line 10 is incorrect.. just include the names of the players.. leave out the number and the bracket...
    Let me know how you get on ...
    -f
    14 minutes ago, AutoFrank said:
    @Hoggle
    If one Sonos is offline (without power) the VD shows an error within Debug.
    Therefore, in that cases, the VD should show "offline" for that Sonos.
    17 minutes ago, AutoFrank said:
    @Patrick
    -f
    ... oops :oops: I do not use any raspberry pi or other api devices, for now stil to sophisticated for me :)
    @Hoggle
    Ahhhh...
    I'll add that to the next version.
    I'm also thinking about having the vd auto-create a global variable for each player to keep track of status so other scenes can trigger off certain states...
    Keep the ideas coming....
    -f
    No worries @Patrick
    It won't work without the api
    Did you see the post that details how you can get it running on a pi reasonably fast...
    Could someone please explain (briefly) the benefits / reasons for running an extra Sonos API from a Raspberry Pi?  What exactly do you get from all the hassle?
    Hi @olekenneth
    Like most solutions it's horses for courses buy for me it gives me 2 things
    Ability to create custom vd's that include music control. I have one for the playroom for the kids and it includes their Sonos and the tv all in one vd. The one for the living room has playlists that can be selected where as the one in the kitchen has the important Sonos, Sat receiver and tv controls
    The second thing is control so I can automate sequences that include player/zone grouping / ungrouping , leveraging presets, pause all-resume all and triggering actions based on state ( tv switched on the playroom automatically stops the playroom Sonos and in groups it from the kitchen)
    Kids to bed scene groups their bedrooms, selects station, stops and ungriups all other upstairs players and lowers the kitchen and living room zones to preset level.
    I also use it for my TTS functions.
    I've had it running for 18 months now and it crashed once when somebody doing work in the house tripped the whole house. I had it back running in 15 mins.
    Hope this helps understand why I use it.
    Hi @AutoFrank ,
    Could you please move this topic to the Downloads? ;)
