Anyone want to help me sort my Lua out?
shaunfrost
I have written an enhancement scripts for boosting the heating in certain rooms based on presence. I already have a zwave boiler controller, and LC-13 radiators with a scripted running base heating scene.. The purpose of this is for certain rooms that meet the following criteria:-
1. Don't need to be heated to comfort level all the time in the heating panel
2. Presence is detected, and the user tends to be in the room for a good amount of time.
2 initial rooms for me are Study and Living Room
I wrote it based on tabulated data, so I could just add additional information into the tables for inclusion, but my lua was "stretched" and there are a lot of loops in loops... it runs fine, but I wondered if anyone wanted to demonstrate how it SHOULD be written :)
or if you want to use it, and you have radiator set points you would like to boost, feel free...
8 answers to this question
Thanks for sharing. The main part of the code is a big, nested, if-then-else structure. This is something I find hard to read. You can improve it by introducing functions. As a rule of thumb, for readability: "the 'if' and 'end' should fit on your screen" or even more stringent "no more than 10 lines between 'if' and 'end'".
I am reluctant to try this kind of script for fun, on my production HC (which is also my test HC... )because it takes me a lot of time to set up and it modifies my "HeatingTable", which doesn't have a simple undo. And to run that on a simulator seems difficult (lots of things to simulate).
    Thanks for that, I am really trying to understand how to enter and exit into and out of functions whilst retaining my "thread". there are quite a lot of arrays that are nested, and I agree it looks wrong, of course it works great, but a script like this shouldn't take 40 seconds to execute!
    I might start small and look at it myself, its a learning curve.
    Oh, but I don't want to suggest your code is wrong, it's simply difficult for me to "read".
    I'll try to modify the code a bit, to reduce the nesting, by introducing some functions. Maybe today ;-)
    It could help me a bit, but it's not necessary, if you send me your hometable and heatingtable via PM (output of fibaro:debug(fibaro:getGlobalValue("HomeTable"))).
    BTW did you just say that the code takes 40 seconds to execute on your HC?
    This has been an interesting experiment for me.. I think I have altered it into as best functions as I can without rewriting completely from scratch, you may be able to read it a little more now...
    the 40 seconds was the reason I was concerned that my nested for loops were a concern, then I realised I put a 20second sleep on each iteration!! I have reduced that to 10 seconds (this is required to allow the TTS to speak on the Sonos before a second command is sent to it, voiceRss lag)
    The HeatingTable is poorly named, it is essentially a Json Table containing data on when the Home Automation last "announced " it was enhancing the room, as I run the script from a main sheduling scene every 5 mins, this table is used to make sure it only announces every 3 hours minimum, you can see the HeatingTable variables being built in the last function (changetimestamp)
    thanks for your guidance.
    Edited by shaunfrost
    wrong attachment
    Ah, you have been busy :-)
    Yes, I saw the sleep() so that's solved ;-)
    You attached your new script as RTF, could you post it as plain text with lua extension instead, please? I recommend "ZeroBrane Studio" as an offline editor, there are a few topics dedicated to this.
    added to post above... lua.
    thanks
    Thanks. That massively improved readability! Really! I had a quick play with it, I added your devices to my simulator and I was now able to run your code. Tomorrow I'll have a closer look at it.
    One silly trick to improve readability: in Zerobrane use CTRL-I to automatically indent the code. The HC web editor can format your code too: do CTRL-A to select all then SHIFT-TAB to auto indent.
