We had another version of the HC2, and I would like to know when plug-in will be made available again?
I keep installing my plugin but keep losing them after an update. I would like to make it permanent.
Any Timelines will be appreciated.
Many Thanks
Chris
Link to post
Many Thanks
Chris
Plugin for?
Link to post
1 hour ago, Jamie mccrostie said:
Plugin for?
@Jamie mccrostie,
User plugins instead of VD. Plugins are giving better user experience and are simple to install and can look better than VD. If Fibaro enable user plugins then I can develop Smarter Coffee plugin instead of VD. For plugin user needs only to give coffee machine IP and port and can start using it immediately without fuss with tampering trough VD code and setting up globals and icons!
Plugins bring simplicity and power to every user. It is really shame that Fibaro still didn't find a way to satisfy security and this great advantage that will give FGHC so big advantage over other solutions.
Link to post
@Sankotronic yes I know what plugins are, i was just interested which one that @fastie81 was having trouble dissapearing after his upgrades
And yes the ones that are there are usally lacking in functionality and there arent enough of them,
Agreed
@Sankotronic I understand that briefly Fibaro allowed user designed plugins
 How was this a security problem?
Or was there just potental to cause the system issues
Edited by Jamie mccrostie
Link to post
The idea of plugins is still great but the problem with a non-proprietary system is that it is dependent on the subsystems.
For example the Samsung-TV-plugin doesn't work with the newer Samsung TVs...seems that Samsung has something changed with the firmware (e.g. port).
That`s why I've lost my faith in a stable, real smart home with a open system.
Link to post
Agreed
Hi Jamie
Sorry, My plugin is for my daikin heatpump/Aircon. This is a plugin that I found on a Fibaro Forum when 4 was in beta and users was able to create plugin, I have since edit it and make it work for me, However I have to reinstall it(AKA backdoor) after every firmware update. On most of the firmwares there was talk about the next one, but we how many into v4 now?
Why this is block I don't understand, as it was said due to security.
But to come back to the question, Is Fibaro going to enable this again anytime soon?
Chris
Link to post
+1. This needs to be brought back as soon as possible to allow us to catch up with Vera, Homeseer, etc. Falling further behind every day...
Link to post
That is they main reason I am asking, cause I am seriously considering moving to Vera again. and I know there is a lot of ppl that would say dont, but Fibaro are make a lot of promises and not really living up to anything.
Sorry bit of frustration sitting in.
Link to post
I still use a Vera as a secondary controller and interface it to my HC2 using API. Vera has a superior DSC alarm plugin, far superior door lock functionality, and far superior geofencing. The Vera app for Android isnt very good but its great on my iPhone. I really hope we can get user plugins back and some good door lock functionality so I dont have to use multiple controllers anymore...
Link to post
