Hi All!
Sometimes also to save storage I try to delete some old backups, but the system says: Access Forbidden.
Is there a rule for making and deleting backups?
B.t.w. yesterday I had the same situation and after rebooting HC2 that backup i intended to delete was gone.
Can't figure out this isuue....
12 answers to this question
Hi
Have just tried for the first time to delete some old backups
On my HC2, no problem
Best regards
DW
HI @Bodyart
No problem here either
Are you logged in as superuser or another account that may not have the correct permissions
Is this happening with all backups, have you tried a more recent on ?
    Hi @AutoFrank,I'm always in as superuser and some backups I'm able to delete and some not. Can't figure out the algoritm...
    I'm trying to keep mostly about 3 backups in order to save the room on USB (recovery) stick.
    Right now I just tried to delete one bakup, without success, then I made a new one. When the new backup was finished, and the gui refreshed, suddenly I saw the backup I tried to delete was gone.
    No alarm in the system when you are trying to delete backup?
    It's just one particular backup i can not delete...
    Hi ALL!
    currently i have 3 older backups, which i'm not allowed to delete...
    The 3 oldest backups give me the following response, when i try to delete one of them
    Anyone an idea what to do??
    Thanks in advance for any advice.
    @Bodyart
    I assume you have tried a reboot ?
    Are they old or recent backups ?
    @AutoFrank,
    ofcourse Frank, i've rebooted many time and tried to delete the backup(s) directly aft3er fresh reboot...
    as you can see in the picture, the backups are from march, june and august this year...
    First i couldn't delete only the oldest one, later also the second oldest and later the 3 oldest....
    Edited by Bodyart
    Go to the "Recovery" tab and run "Checksum". If it says NOK you have an issue with your hardware dongle. If the test says OK, it might be only the individual backups that have been corrupted.
    There was an issue with some (special or international) characters in backup names several firmware versions ago,  I am not sure this is still relevant.
    You might read posts that tell you to plug the recovery drive in your PC and clean up... but I am not fond of that solution. It might make things worse. I'd contact support so they can remotely diagnose the problem (run a disk check program and clean up invalid files).
    Thanks @petergebruers for that idea.
    The checksum seems to be ok. I've just verified it, see below:
    I didn't use any diacritics in my devices, or scenes.
    @Bodyart thanks for trying that. Checksum OK gives some reassurance. Unfortunately, I've got no more wise words...
    @petergebruers,
    thanks Peter for your support anyway. B.t.w. i did try the checksum already earlier and it was OK all the time. I'm afraid I have to contact the Fibaro support then....
