HCL no local network connection even though connected directly to router
shinbo
Hey guys, I'm facing a connection issue with my new HCL. I tried to update to latest firmware, after the HCL restarted, only the power LED is on.
HCL is connected directly to router, and the ethernet cable is verified working. I'm unable to detect the HCL on the local network via the Fibaro Finder app even after trying to boot in recovery mode. Any ideas? Thanks!
Hi Shinbo, I'll suggest you to reboot the HCL. I solved this issue with a daily programmed reboot through scene program.
I hope this will help you.
