Hiding some plugins
Hi ALL!
Wouldn't it be nice to have the possibility to make som plugin device hidden like the others in order to get the things better organized?
Link to post
I agree it would be very useful if plugins and VDs could be put into categories such as lighting, climate, blinds, etc or be hidden!!
Link to post
Well, some plugin components can be hidden, like Netatmo plugin sensors while Philips HUE plugin can't be. Only solution is to either leave them in unassigned room or make one room like "Resto" or "Attic" or "Basement" and then put those unwanted elements there. :)
On the other hand, possibility to sort plugins and VD's under categories like lighting, climate, etc. would be really nice!
Link to post
Thanks you for the suggestions! I have added the suggestions to the improvement ideas ;-)
Link to post
Being able to have plugins in their correct categories has come up before and is still very valid now. Being able to use Philips HUE bulbs as normal lights for instance should be a high priority for Fibaro as I can see many users who are tempted by Fibaro HCL/HC2 would already have HUE lights and it would make the transition more appealing.
Link to post
