Dual Switch 2 different model?
Bodyart
Hi All!
I have 2 Double Switch 2 devices installed now and i see big differences, see below.
Double Switch 2
Serial number: 33777
Parameters template: 781
Has four slave devices i.e.:
1 On/Off switch
2 Controller with 8 scene triggers
3 On/Off switch
4 On/Off switch
Another Double Switch 2
Serial number: 33781
Has also four slave devices i.e.:
1 On/Off switch
2
com.fibaro.heatDetector
3 On/Off switch
4 On/Off switch
Apparently both devices use template 781, but they appear totaly different even some icons are different.
Anybody some explanation?
do soft reconfiguration on both and compare them again ...
    I'll try that, thanks for the hint
  • Indeed, but only after soft reconfiguration twice, i gain the same configuration. Thanks @tinman
