Sankotronic Lab - Universal Home Automation System (UHAS™)
Sankotronic
"Fibaro Home Center with UHAS will boldly go where no one has gone before!"
UHAS UPDATE INFO on 31.12.2021.
CURRENTLY WORKING ON
  • Please check below OVERVIEW OF UHAS MODULES for the current progress
NEW INTEGRATIONS PLANNED
  • Netatmo thermostat
  • Netatmo doorbell (waiting for API to be published)
  • Sensibo smart air conditioner controller
  • Blebox smart light control modules
UHAS INCLUDED INTERGATIONS
  • Netatmo Weather Station
  • Netatmo Public Weather Station
  • Netatmo Coach (air quality modules)
  • Netatmo Welcome and presence cameras
  • WeatherFlow 1st gen weather station
  • WeatherFlow Tempest weather station
  • Ambience Weather stations
  • Hydrawise irrigation station
  • Philips HUE lighting - UPDATE(10.12.2021) - working on solution for new HUE API v2
  • Nanoleaf Aurora light panels
  • Nanoleaf Canvas light panels
  • Nanoleaf Shapes light panels
  • LIFX color and white WiFi lights
  • LaMetric smart alarm clock
  • Sonos speakers
  • Twinkly Christmas lights (NOTE latest firmware update breaks integration!)
  • Smarter Coffee 1st gen
PREVIOUS WORK DONE
  • UPDATE (31.12.2021) - Today is the last day of this year. I'm again behind the schedule :-( It took me almost 4 weeks to further optimize code of 80 VD's and 32 scenes, but it was worth it. UHAS is now running stable and responses are fast on system with 106 z-wave devices, 102 VD's and 49 scenes, but also extended RAM memory to 2Gb. I still have to test it on original setup with 1Gb of RAM. I was also busy with Philips HUE new API. What they did with new API is first removed support for HS (hue/saturation) so now we have only XY color space and MIREK or color temperature. Then they also removed "effects" and only existing "colorloop" and replace it with "gradient" that refuses to work with my color bulbs, most probably because I still don't understand how to use it 😮. Anyway, I managed to find out how to work with single bulbs and also with scenes on group of lights. On the old API when requested to send all settings, response JSON was nicely sorted with lights, scenes, groups, sensors parts. New API is now just a big bunch of unsorted data and to get something from it you have to loop through that very big JSON and try to find what you really need. So, best way to get soehting from bridge is to do several requests separated for lights, rooms, scenes etc. Not to bother you further with this, Philips new API is just a big mess of everything and some things that were missing on old API, are still missing on new one. It is as they admitted, not a finished yet. I should have soon a working set of VD's and scenes to control HUE lights, but I will not bother for now with sensors, buttons and other devices.
  • UPDATE (10.12.2021) - Yesterday 09.12. I started with moving new UHAS from developing HC2 to my working HC2 so I can do final testing in real life and also finish some parts that I can't do on developing HC2 due to lack of various devices. This is also needed to clean all bugs related to installation of UHAS. Even I can see the finish line now I still can't tell you the exact release date because in the meantime Philips decided to replace their HUE API v1 with v2 which is major upgrade and will discard the old API. I have done some preliminary testing of HUE API v2 and I have to completely rewrite HUE for HC2 and do SMART combination of VD's and scenes so that it just works and works fast and that users do not have to do anything inside code to make it work after installation. All this is because HUE API v2 will not support HTTP calls any more which forces me to use scenes to communicate with HUE bridge. Also what is left to be finished is translations and installation and user manual. UHAS is opened for future expansion and users will be able to add their own solutions, but to be able to do that I have to provide some information on how to do that. I have also made UHAS SDK that contains all necessary code snippets and functions that can make any solution UHAS compatible. So keep fingers crossed 🤞 because finish line is definitely close! Will keep you informed and thank you for the support!
  • UPDATE (07.12.2021) - Flood and Fire alarms done. Automatic search and setup of flood and smoke sensors immediately after installation. Possible add additional sirens and also valve control. Will close added valve(s) for water in case of flooding. Fire alarm can close gas or fuel valves in case of fire. User can also add other actions as needed. Also alarm notifications can be sent to all UHAS available services (TTS, LaMetric, push, popup, e-mail, pushover, telegram, groupme...) Since Philips decided to upgrade HUE API, now working on upgrading UHAS ALC module to support this. Since HC2 VD does not support HTTPS calls have to use scenes to communicate with HUE bridge, so now testing several solutions to have smooth control and also feedback. I was really hoping to release UHAS this week, but due to some problems and this Philips HUE API changes have to postpone for few weeks :-(Primary problem was with global variables that keep translations to 20 different languages. Since they grew beyond Fibaro HC2 limits first I have reduced number of languages form 27 to 20. After finishing ANC and adding all new notifications this appeared not to be enough. So now I have modified system in the way that users will have to request what languages like to have and then will provide only requested languages. This solution now also enables UHAS to be translated to any language on request. :-) I have added few new pictures for Flood and Fire alarms. I should actually update all pictures since most of the VD's are in the meantime upgraded and enhanced primarily for better functionality, but also visually.
  • UPDATE (07.11.2021) - WOW, time is really passing quickly when I'm busy. In past few weeks I was mostly busy studying to pass exam and get yet another certificate for my next job which I successfully done. This week I'm completely devoted to coding UHAS. Mostly I was correcting or improving some of the modules. Today I'm also finishing Sonos API Master VD that can replace few Sonos API Players for Sonos speakers that are mostly always joined. Also finishing Sonos API Setup VD that will simplify setting up some default settings, like volumes for different times of day, also volumes for TTS, changing radio stations or playlists and even timer to set news radio station for news broadcast and then go back to previous music. Then continue on working alarms and appliances monitoring. UHAS must be ready for publishing at least 2 weeks before Christmas and will do my best that this happens even if some things will still not be ready. The rest can be always added later. Fingers crossed 🤞
  • UPDATE (04.10.2021) - Advanced Lighting Control (ALC) is finally done :-) I still have to do more testing for different situations, different types of lights and configurations, maybe improve few things, but it is now already working nicely. The biggest advantage of the ALC over VSL is that users can now easily setup lights without needing to see a line of LUA code except for setting motion and lux devices. But once motion and lux devices are setup, all other settings can be done with Mobile app. User can use ALC Configuration VD to setup all lighting for the selected room. ALC suite has now also included ALC Mimic VD which is responsible to learn and then control lighting while users are away from home. With learning mode enabled it will record lights events for 24/7 period and then use this recording to mimic lights when needed. Even recording of lights events should be sufficient it is still possible to add events manually. I will soon provide more information on ALC features. Please check pictures below.
  • UPDATE (15.09.2021) - Sun Calc. VD + Moon Calc. VD + scene is added to the UHAS family. Please find more information below. Also picture is provided under the UHAS Schedule module
  • UPDATE (07.09.2021) - Alarm Clock (VD + scene) is DONE. Please find more information below. Also picture is provided under the UHAS Schedule module
  • UPDATE (01.09.2021) - Watchdog (VD + scene) is DONE. Please find more information under the OVERVIEW OF UHAS MODULES. Also added picture.
  • UPDATE (28.08.2021) - UHAS all existing components are now updated to the latest integration specs. Many components are upgraded to update global variables that can be used as triggers in user specific action scenes, especially climate components like Netatmo, WeatherFlow and Ambience weather stations. ANC (Advanced Notification Center) Has now new ANC Message Queue VD which can be used to check all queued notifications and reason why where not sent (Sleep, error sending, internet down), but instead saved in queue. All messages in queue can be then listened on speaker or resend. List of done changes, corrections and new stuff is long to publish here. UHAS at this moment has 63 virtual devices and 27 scenes ready for distribution. I still have to made few more to cover all must have automation. Please check table bellow with current status of the UHAS components. Once it is finished it will be possible on users request to add more integrations that will be easy integrated to UHAS thanks to UHAS SDK that I have made during work on UHAS.
  • UPDATE (23.05.2021) - Advanced Lighting Control (ALC) - Currently rewriting Philips HUE, Nanoleaf and LIFX code for better integration with ALC. Also to support Advanced Notification Center notifications. Basic learning code is done, but needs comprehensive testing under different situations. Irrigation Control - Also working on Irrigation Control that will work and solve some deficiencies of HC2 Sprinkler panel like limitation of only 15 minutes watering duration and also overlapping of zones watering when watering adjustment is applied. Advanced Notification Center (ANC) - is finished and in process of testing and improving. Also lots of translations of notifications still needs to be done. With new Sonos API Player and ANC it will be possible to send TTS notifications in different languages than the one set for HC2 and UHAS. Also LaMetric smart clock is completely integrated with notifications, radio and alarm clock. Weather State & Forecast and Netatmo Weather Station modules are also updated when their standalone version are updated to support new weather services. Sonos API Player is upgraded to support doorbell and security alarm sounds. Also handling of TTS notifications is modified for multi language support. Lithe Audio Player is now also integrated to UHAS and now working on adding doorbell and security alarm compatibility in parallel with work on QA version. Also hope to do some better handling of supported music sources.
  • UPDATE (29/12/2020) - UHAS is completely reorganized and I have reduced number of modules. This does not mean that UHAS final version is reduced and it will still have all planned components. More about reorganization you can see below in Overview of UHAS modules. I also had to reorganize Translation module and move translations from individual VD's to scenes for easier maintenance. During testing I have also realized that I have to improve stability and reliability of VD's main loops since in some cases they where stop running when global variables where damaged or even deleted. This are last changes that I had to do. Translation module is done only some translations still have to be made. System module is also done regarding stability changes, but now I'm adding last needed parts. Automatic backup is finished that includes one VD and one scene. Users will be able to manipulate backups from mobile apps, setup automatic backup and manually delete or create backups. Automatic backup to cloud takes care of free space and in case there is not enough space for new backup it will automatically delete oldest backup without needing user intervention. System Watchdog and Event Viewer I'm now working on. System Watchdog purpose is to monitor UHAS and restart any VD main loop or scene if found stopped running. With latest stability improvements that might seem as unnecessary, but I also found main loops and scenes to stop running without any errors if are making HTTP and HTTPS calls. System Status VD is checking internet connection and Network Scan VD is checking local network selected devices connection and prevents this calls in case connection is lost, but still it can happen in some rare cases. ANC (Advanced Notification center) is still not completely finished. I'm still now adding ANC support to all other UHAS components and testing. ANC is also one of the reasons I had to do changes to Translation module to have translations for notifications on one place. System Control VD can now restart UHAS and reboot HC2 in the controlled manner and also reboot router if connected to z-wave smart plug or any other plug that is controlled with VD. There are other numerous improvements done to UHAS that will not mention here. Main scene FTBE separated timers and scheduling part. Scheduling part improved to be able to control more different devices. Timers part will be moved from scene to Sunrise & Sunset VD to keep only one scene always running. There is a long list of other improvements made in last few months, but it would take too much time to put it here. :-)
  • UPDATE (29/11/2020) - Twinkly Lights VD - finished both versions for UHAS and standalone. Ambient Weather VD - updated to support more stations thanks to @gklurker providing me access to his station. ANC module - have to do some changes to the initial setup, so now adjusting other modules to use this new setup. UHAS all modules - done some changes to the debug part. Added current date to be also displayed for easier understanding when events occurred. ALC module LIFX VD - updated global variable for better usage with learning mode. Presence module - Added solution with mobile apps like Geofency, Locative and similar. Still working on tuning up and adding notifications. Sonos API Player VD - added possibility to get playlists from My Sonos and also select and start playing, same as for favorites. See picture of new VD under Multimedia module. System Status VD - Now added checking of router VLAN IP address and it is shown on VD label together with time of last change. Also if setup VD will send notification whenever VLAN IP is changed.
  • UPDATED (12/11/2020) - Improved Sonos API Player VD - that now can control group/ungroup speakers and gets favorites from Sonos app. Twinkly LED lights VD/scene - for now can turn on lights with last selected scene and turn off. API is still not made public so there are some setbacks :-(COVID-19 Stats VD/scene - updated to work with new endpoints and API key. Weather & Forecast VD/scene - corrected some bugs and looking for additional weather services
  • UPDATED (03/04/2020) - Added support for Netatmo presence outdoor camera. Upgraded all currrent UHAS modules to support new Advanced Notification Center and LaMetric clock. Not to list all changes and improvements see list and pictures below
  • UPDATED (28/12/2019) - - Added support for
     (Coach). New scene and VD's support any number of the Coaches installed in users home. Completely made new sets of Philips HUE VD. HUE Group VD now supports HUE scenes. User can select and activate any of the available scenes that are added using Philips HUE original mobile app, check spoiler for picture. AIO VD is now replaced with set of VD's that are suitable for use with bulb type. For example, dimmable bulbs have only brightness and transition speed sliders, while full color bulbs have sliders for brightness, hue, saturation, color temperature and transition speed.
  • UPDATED (24/06/2019) - Added logo and new MOTO
  • UPDATED (19/06/2019) - New added to UHAS is integration of
    and
    LIFX integration was demanding since LIFX LAN protocol utilizes UDP/IP communication with binary packets of data in little endian. First version of LIFX Color VD will not include effects support since effects are not available yet as programs, plugins or chunks of data available through API so have to be builded on software platform in this case as part of the LIFX Color VD. Weatherflow station becomes more and more popular for its possibilities and open API so UHAS integration is done. For now Weatherflow Air and Sky modules are supported fully! :-) I'm also working on integration of
    and
    ! Due to some new exciting development with UHAS project there will be no time to make stand alone versions of this latest integrations except if there will be really great demand for that :-D
  • TRANSLATION MODULE
    • Global translation scene - Translation of VD's and predefined global variables to 27 languages. (DONE)
    • System translation scene - Translations of UHAS system module to 27 languages. Scene is constantly updated as other components are changed or added (IN PROGRESS)
    • Climate translation scene - Translations of UHAS climate and ambient modules to 27 languages. Scene is constantly updated as other components are changed or added (IN PROGRESS)
    • Notifications translation scene - Translation of notifications to 27 languages. Scene is constantly updated as other components are changed or added (IN PROGRESS)
    • TTS translation scene - Translation of text to speech notifications to 27 languages. Scene is constantly updated as other components are changed or added (IN PROGRESS)
    • Select language VD - Scene companion to select desired language. (DONE)
  • SYSTEM MODULE
    • System Control VD - Start/stop running selected UHAS module or complete UHAS for software and hardware upgrades. Now can also restart UHAS and reboot HC2 in controlled manner. Can also reboot internet router that is connected to z-wave smart plug or any other plug controlled by VD. (DONE)
    • Reboot scene - Controlled reboot or shutdown of the HC2. Works with System Control VD. (DONE)
    • Remote Reboot scene - Scene that works with interactive push notification. If user gets notification that system needs to be rebooted can do that from smart watch or mobile phone. (DONE)
    • System Backup (VD+scene) - Automatic backups and backup manipulation. (DONE)
    • System Status VD - Shows current status of the complete system. Supervision of internet connection and available system updates. (DONE)
    • System debug VD - Selection of what will be shown in debug windows of VD's and scenes. (DONE)
    • System Watchdog (VD + scene) - Watchdog is responsible to monitor all continuously running scenes and VD's main loops. In case that scene or VD main loop stops running for some reason it will try to restart them and will notify user. Thanks to UHAS advanced notification center user can select how to be notified. Also Event Recorder if activated for Watchdog will record all this events for later checks. While Watchdog scene is monitoring other scenes and VD's, Watchdog VD is monitoring its companion scene for higher security. User can check with mobile app current status of the watchdog and control it. (DONE)
    • Icon Preview VD - Setting up of icons for VD's. (DONE)
    • UHAS Emoji VD - UHAS is using emojis a lot. With this VD users can check emojis code names and use in their additional LUA coding. (DONE)
    • Advanced Battery Check VD - Supervision of battery levels for battery operated devices and sending notifications for replacement.(DONE)
    • Network scan VD - Scans local network for devices used with UHAS automation and if found off line sending notification to check device. (DONE)
  • SCHEDULE MODULE
    • Main scene FTBE - Beating heart of UHAS. Scene takes care of all user specific scheduled and repeating actions. (DONE)
    • Main Timers scene - Take care that HC2 always knows what is time of day, season, weekday etc. (DONE)
    • Sunrise & Sunset VD - Gives complete control over the time of day changes which influence lighting behavior and many other features. It will use sunrise and sunset times from Sun Calc VD if installed which is more correct than HC2 . (DONE)
    • Sun Calc VD + Moon Calc VD + scene - This suite provides more information about movement and position of Sun and Moon. Sun Calc. besides sunrise/sunset time it also provides length of the day, solar noon and sun position. Also Moon Calc VD provides moon rise, moon set and moon phases. (DONE)
    • Home Timers VD - Shows current status of the most important timers. (DONE)
    • Alarm Clock suite (VD+scene) - Fully configurable alarm clock with multiple wake up settings including control of lighting, music, blinds etc. User can setup any number of alarms with different time settings with any weekdays settings. It is easy to activate/deactivate selected alarm or all alarms at once. Alarm Clock will also find LaMetric Alarm VD if installed and enable control of this smart clock. It will depending on alarm settings automatically activate or deactivate alarm on LaMetric. Alarm Clock VD can be used as single device or can be installed each VD for each bedroom to give more flexibility to family members to wake up at different times. (DONE)
    • LaMetric Alarm clock VD - Complete control of the nice informative alarm clock LaMetric. (DONE)
    • Sleep Mode suite (VD+scene) - user can define complete house behavior when set to sleep. Depending on other modules installation can provide calm music on selected speakers with sleep timer. Also control of lighting, alarms, notifications etc. (IN PROGRESS)
  • NOTIFICATION MODULE
    • ANC (Advanced Notification Center) VD - Scans for all scenes and VD's that sends notifications and gives users easy way to setup what messages will be sent to which user and service HCpush, HCpopup, e-mail, Pushover, Telegram and/or GroupMe or just saved to message queue. (DONE)
    • ANC (Advanced Notification Center) scene - scene is responsible to send messages or save them to queue and is part of the ANC VD. If TTS and/or LaMetric ANC part is installed then will also trigger those scenes to send notifications. (DONE)
    • ANC LaMetric VD - Support for LaMetric Clock to receive and show notifications selected by user. (DONE)
    • ANC LaMetric scene - Support for ANC LaMetric VD to send notifications to selected LaMetric clocks. (DONE)
    • ANC TTS VD - Support for Sonos ARC Player and Sonos API Player to send TTS messages to selected speakers. (DONE)
    • ANC TTS scene - Support for Sonos ARC Player and Sonos API Player to send TTS messages to selected speakers. (DONE)
    • ANC Message Queue VD - VD to handle all queued messages, resend or listen queued messages on TTS speaker. (DONE)
    • LaMetric Icons VD - Enables users to download list of LaMetric icons from server and then select from that list favorite icons to use in own notifications. user can easily find favorite icon code, but can be used only with browsers to show icons. Icons can't be seen on mobile apps. (DONE)
    • LaMetric Icons scene - support for LaMetric Icons VD to get icons from internet. (DONE)
  • REPORTS MODULE
    • Report recording suite - still in planning and design stage. At the moment testing InfluxDB and Grafana. (IN PROGRESS)
    • Event Recorder VD - User can start/stop events recording for any UHAS component and preview/delete events as needed.  (DONE)
  • CLIMATE MODULE
    • Weather State and Forecast (VD's+scene) - Get weather state and forecast from most popular weather services like Open Weather, WeatherBIT, WeatherHERE, WeatherAPI, Weather Unlocked Weather Underground. (DONE)
    • Netatmo Weather Station suite (VD's+scene) - Supports more than one Weather station with support for all available modules including rain and wind sensors. (DONE)
    • Netatmo Public Weather Station suite (VD+scene) - For users that do not have their own weather station can install this suite and have more accurate data for precipitation, wind, temperature and humidity for their location. (DONE)
    • WeatherFlow Station suite (VD+scene) - Supports AIR and SKY modules. (DONE)
    • Tempest Weather station suite (VD's+scene) - Integration to UHAS is done and tested. (DONE)
    • Ambient Weather station VD - Access an Ambient Weather user's weather station data programmatically using REST API. (DONE)
  • LIGHTS MODULE
    • ALC (Advanced Lighting Control) suite (VD's + scenes) - This should be most advanced lighting control ever made. It will give users complete control over the lighting for each room and complete home. Possibility to use predefined lighting scenes and to add more. Learning mode will remember settings for all lights as they are setup by user per each lighting scene. (DONE)
    • Philips HUE Preview VD - Philips HUE lighting control. It supports multiple HUE bridges and most of the available types of bulbs. It also supports HUE scenes for group of bulbs that are made with HUE mobile app and HUE Group VD can use those scenes to control lighting. (DONE)(UPGRADING)
    • Philips HUE Group VD - Control of HUE group of bulbs (grouped in one room) and now also with HUE scenes, default like "Energize", "Reading" and also user made. (DONE)(UPGRADING)
    • Philips HUE Color ambience VD - Control of individual HUE color bulbs. (DONE)(UPGRADING)
    • Philips HUE White ambience VD - Control of individual HUE white ambience bulbs. (DONE)(UPGRADING)
    • Philips HUE Dimmable VD - Control of individual or group of HUE white dimmable only bulbs. (DONE)(UPGRADING)
    • Philips HUE wall plug VD - Control of HUE and some other compatible smart wall plugs. (DONE)(UPGRADING)
    • Nanoleaf Aurora VD - Control of Nanoleaf Aurora light panels including Rhythm module if added. (DONE)
    • Nanoleaf Shapes VD - Control of Nanoleaf Canvas and Shapes light panels. (DONE)
    • LIFX Color VD - Control of individual LIFX Color WiFi bulbs. (DONE)
    • LIFX White VD - Control of individual LIFX white dimmable only WiFi bulbs. (DONE)
    • Twinkly LED light VD - Done integration. Tested with Twinkly 2nd gen 250 LED strings and Twinkly 2nd gen 190 LED icicle. WARNING: Last Twinkly firmware upgrade breaks integration! Looking for solution. (IN PROGRESS) For those that still didn't upgrade to last firmware is (DONE) :-)
  • BLINDS MODULE
    • VSB (very Smart Blinds control) suite (VD+scene) (In development) - User can setup how blinds will be cotnroled, same as for lights in ALC suite (in alpha development). (IN PROGRESS)
  • SECURITY MODULE
    • HC User Setup VD - Expansion of HC2 user and mobile devices setup. (DONE)
    • Home Status VD - Shows current status of the home (DONE)
    • Burglar Alarm suite (VD+scenes) - User will have complete control over arming, disarming alarm depeding on different situations, work, vacation, sleep including pets whereabouts. (IN PROGRESS)
    • Netatmo Cameras suite (VD+scene) - Support for Netatmo welcome and presence cameras with possibility to suspend/reactivate monitoring of all cameras at once or only for selected camera. With geofencing turned on can be used for presence control (away/home) with personal welcome actions thanks to face recognition. (DONE)
    • Presence VD - Installed for each user of HC2 and can be used manually to change present state or remotely by mobile app such are Geofency or Locative using direct webhook and special user that is only allowed to access this VD(s). Can also send notifications when user presence is changed. There are also added several more locations of interest like: at school, at work, at family, in shopping and on holidays. (DONE)
  • SAFETY MODULE
    • Fire Alarm VD+scene - Monitoring and notifying if any of the sensors are breached plus additional actions. (DONE)
    • Flood Alarm VD+scene - Monitoring and notifying if any of the sensors are breached plus additional actions. (DONE)
    • CO Alarm scene - Monitoring and notifying if any of the sensors are breached plus additional actions. (IN PROGRESS)
    • Advanced Radiation Monitor VD - Shows nearest 5 radiation monitoring stations and one with the highest measurements. (DONE)
    • Air Quality VD - This VD uses API that is provided by the World Air Quality Index project. It uses China mainland air quality index and shows user nearest station measurement. (DONE)
    • COVID-19 Stats suite (VD+scene) - Monitoring of pandemic for whole world and for user selected country with complete history at hand. Will inform about changes for global pandemic changes or only for selected country. Since most of the COVID API's are depreciated it is (ON HOLD)
  • AMBIENCE MODULE
    • Netatmo Thermostat (VD+scene) - Integration of Netatmo thermostat + radiator valves to HC2. (IN PROGRESS)
    • Netatmo Air Quality Monitor (Coach) suite (VD+scene) - Support for any number of Netatmo Coaches. (DONE)
    • Sensibo AC smart control VD - Will allow to control any AC unit that has IR remote control. This is at the moment in stand by. (IN PROGRESS)
  • APPLIANCES MODULE
    • Home Energy suite (VD+scene) - Monitoring of complete home consumption (with tariff) with notifications and possible control over the biggest consumers. (tariff part collecting information). (IN PROGRESS)
    • Appliance Energy Monitoring (VD+scene) - Monitoring of individual consumer with historical data. (IN PROGRESS)
    • Appliance Monitoring suite (VD+scene) - Simple monitoring if the home appliances with notifications. (IN PROGRESS)
    • Smarter Coffee (1st gen) VD - Complete control over the 1st gen coffee machine (working on next generation, but since Smarter is still hiding API more time is needed to investigate. Any help with this one is greatly appreciated). (DONE)
  • MULTIMEDIA MODULE
    • iTach TV remote control VD - Requires iTach IP2IR and can control any TV set after learning TV remote IR codes. (DONE)
    • iTach IP TV remote control VD - Requires iTach IP2IR and can control any IP TV set after learning IP remote IR codes. (DONE)
    • iTach Soundbar remote control VD - Requires iTach IP2IR and can control any soundbar set after learning soundbar remote IR codes. (DONE)
    • Sonos ARC Player VD - With the permission of author @Krikroff VD modified to work with UHAS system and also changed favorites handling. (DONE)
    • Sonos API Player VD - Requires Raspberry PI or any other computer to run jishi node-sonos-http-api to work. Latest version includes better handling of favorites, playlists and ability to group/ungroup Sonos spekares. (DONE)
    • Sonos API Master VD - Requires Raspberry PI or any other computer to run jishi node-sonos-http-api to work. Master version can replace several Sonos API Player VD's for speakers that are most of the time joined in group. Additional feature is Sleep timer, setting up group and then joining all at once. (DONE)
    • Sonos API Setup VD - Requires Raspberry PI or any other computer to run jishi node-sonos-http-api to work. Easy setup some default settings like volumes for different times of day, also volumes for TTS, changing radio stations or playlists and even timer to set news radio station for news broadcast and then go back to previous music. Then continue on working alarms and appliances monitoring. (IN PROGRESS)
    • LaMetric Radio VD - It allows users to start/stop playing last selected radio station and also to select radio stations that where setup with mobile app as favorites. It also includes timer when to start playing radio and stop. Nice feature not to miss latest radio news. (DONE)
    • Watch TV VD - programmable VD to start/end wathcing TV. Does all necessary steps, either preprogrammed or user additional like change lighting scene, lower blinds (during day), stops music, selects desired TV channel or just activates other video source. (DONE)
  • ACCESSORIES MODULE
    • Irrigation Control VD - Brings complete control and overview over the Sprinklers panel. Solves problem with 15 minute watering duration limitation and also with zone watering overlapping when watering adjustment is applied. Works nicely with Weather State & Forecast and Netatmo weather station to automatically adjust or delay watering depending on current and forecast rain precipitation. Control your irrigation from any location with mobile app. (DONE)
    • Irrigation History VD - Irrigation Control VD companion which provides history on times and duration of past watering cycles and weather state. Default history is set to past 7 days, but can be setup by users to any number of days. (DONE)
    • Hydrawise Control VD - Integration of Hydrawise irrigation controllers with HC2. Have current status of controller in HC2 and control watering on the go. VD can delay watering depending on current and forecast rain precipitation (requires Weather State & Forecast suite + either Netatmo Weather station or Netatmo Public Weather station suite). (DONE)
    • Swimming Pool Control VD - Complete control of the swimming pool over the pump, water temperature and chemical levels. (DONE)
    • Solax Power (VD+scene) - (NEW) Integration for Solax Power inverters. More about:
        Just monitoring and storing history data (IN PROGRESS)
    • Get Geolocation scene - Scene that can be called from other scenes or VD's to get address (street, county, city, country) data by providing longitude and latitude. It uses developer HERE reverse geolocation service and requires free account with API_KEY, same one that is needed for WeatherHERE service in Weather State & Forecast suite. (DONE)
  • OTHER MODULE
    • Anything else that can't be sorted under other modules.
UHAS IN PICTURES
UHAS Translation module:
UPDATE (04/10/2021)
I have added latest picture with all UHAS components finished. This is still picture from the development HC2. I still need to finish few more things and then will start first installing UHAS on another testing HC2 to solve any possible problems that can show up during installation and then will go to my main HC2 replacing old solution.
UPDATE (01/09/2021)
I have removed my working system picture since it is still running older version of UHAS and I added picture of the latest UHAS that is now still running on my development HC2. In next several days I will first install new UHAS on another HC2 which is prepared for this final testing. I need to check and solve any possible problems that can occur during clean installation. During this clean installation and setup will do my best to make as more pictures and videos as possible. Final test then will be then installation of UHAS on my working HC2. Some UHAS components I will be able to finish on my working HC2 since there I have all needed devices included. On development HC2 I have just few devices included that I still haven't include on my working system.
UPDATE (12/11/2020)
My system at time of writing update: 29 rooms in 3 sections; 110 z-wave devices; 83 virtual devices; 67 scenes; 8 cameras
Unfortunately, previous plan about date of publishing UHAS has changed due to COVID-19 pandemic and my work. I was not able to work on UHAS from 25th April till 22nd October this year. Even I'm now investing most of my time to work on UHAS, there is a little chance that it will be ready for publishing as previously planned. Most likely it will be ready for publishing in first or even second quarter of 2021. Wiil do my best to be as earlier as possible, but there are some things that just can't be predicted and that can influence my work on UHAS.
UPDATE (19.01.2020)
My system at time of writing update: 28 rooms in 3 sections; 109 z-wave devices; 80 virtual devices; 67 scenes; 7 cameras
I started building my system in December 2015. UHAS idea was born in 2016 when I started sharing some of my work here on forum. Each script I wanted to share, first I had to change to suit other users so I started thinking why not write code that is universal. Serious work on UHAS started in 2017. In that time I was really optimistic that I can make it till the end of 2018. Unfortunately due to my job to which I have to give more than half of my life and also some setbacks either caused by Fibaro new releases or me and my lack of knowledge we are now looking at the end of this year, but more likely first or even second quarter of 2020. Last two months I have invested in rewriting most of the UHAS code due to some limitations of the current HC2. That is now done and I'm ready to continue to do the rest of the modules.Soon I will have to go to my work again for at least four to five weeks, but will continue to work hard on UHAS when I'm back home.
Besides rewriting UHAS code I have made new Philips HUE VD family that now supports also scenes that are made on Philips original app. So no more HUE AIO VD (all in one) but now there is a family of VD's for control either group of lights with scenes or single bulbs depending on type Color & White ambience, White ambience and Dimmable only. Still HUE Group Control VD is the most advanced one that provides control of complete room or zone with HUE scenes.
UHAS PRESENTATION
UPDATED (26/04/2019)
Since pictures are worth thousand words I made new presentation (click to download):
UPDATED (04/12/2017)
This is older presentation left for comparison. Latest presentation is on top of this post (click to download):
Thank you for following
Will keep you updated regurarily so stay tuned!
Sankotronic
Edited by Sankotronic
Latest upate on 31/12/2021
  • Like 18
  • Thanks 9
@Sankotronic, my wife is mad at you already without knowing about this ;)
I for sure am going to enjoy implementing this AND learning from you!
The offer to test thing still stands!
Jim
Exciting news! Simplified installation of Time Based Events, VLS is welcomed especially with so many options to configure through the code!
Aiming high! Remember you have established a solid track record to defend!
  • UPDATE
    Weather State VD:
    • Corrected weather icon table to show proper weather status. Expanded choice of icons that can be added. Icons can be easily set by new version of Icon preview VD.
    • Weather can be now retrieved from openweathermap.org and wunderground.com
    • Added 6 day forecast that can be retrieved from both openweathermap.org and wunderground.com
    • Added button for sending weather status notification (main scene can be setup to do that at selected times and days of the week)
    • Main code moved to refresh button which can be pressed by Main scene repeating VD function
    • Multi language support for 24 languages, all that are supported by HC2 plus additional languages selectable by user.
    • Weather Forecast VD added that can display forecast for next 6 days and can send forecast notifications activated by Main scene scheduled VD function
    Netatmo weather station scene and VD's
    • Further optimized code
    • Added multi language support for 24 languages, all that are supported by HC2 plus additional languages selectable by user.
    • Scene is now updating all VD's so there is no need for any extra code
    • VD's icons can now be set easily with Icon Preview VD
    Main scene FTBE
    • Optimized code to run synced with HC2 clock.
    • Added delays between scheduled and repeating scenes and VD's to even load on CH2
    • All global variables are now added automatically by Sunrise & Sunset VD
    Sunrise & Sunset VD, Home status VD and Home Timers VD
    • VD is taking care of all global variables needed so user doesn't have to do anything about that
    • Global variables are now added under predefined variables panel so cannot be destroyed by SAVE button in variable panel any more.
    • Extended margin times and added fixed times for all periods of day.
    • Removed blinds time control since it will get it's own scene & VD
    Translation scene & Select language VD
    • Brings support for 24 different languages. Automatically translates scenes and VD's to language selected on HC2 or additional languages selectable with Select language VD. Easy upgrade or translation correction, user just need to copy/ paste and save. It auto runs and takes care that translations are corrected and selected by all scenes and VD's that support this feature.
    Very Smart Lights™ scene
    • Like 3
    Looks promising!
    First glance: Wow
    I´m hoping that impression lasts when the you release this solution!
    Edited by 1152
  • 1 hour ago, 1152 said:
    Looks promising!
    First glance: Wow
    @1152,
    Me too :-)
  • Hi all,
    I'm a bit frustrated with Fibaro! It is really unbelievable  how VD's are displayed completely different on web GUI interface, iPhone app, iPad app and when it is open for editing!! Here it is what I mean:
    First one is the best, but that you can see only when you open VD for editing. Second is normally opened VD on web GUI. Why can't be same as first one?! Third one is from iPad and it is just slightly better than last one from iPhone because used font is smaller and iPhone is DISASTER!!!
    BTW, on above pictures is Weather forecast VD. It is almost finished but I'm really struggling with what to display and what to remove. Forecast from Wunderground.com is even worse because they have nice but long description that just don't fit on iPhone OLD application with GUI from times when first iPhone came out :huh:
    Below is the v2.0 on the Android app.
    Looks better then iPhone. Think that one needs some TLC
    Jim
    At this moment i'm glad to use android :-)
    But agree with @Sankotronic, that the displays shoul'd be at least a bit similar otherwise some information (functionality) may become malformed. Let's hope the Fibaro guys are reading with us.
    Jim
    Hi Jim,
    That is definitely much prettier than on iOS. I'm thinking to get one android for testing purposes. Nothing special, fancy shmacy and definitely not too expensive. Maybe some Chinese phablet :-P Do you have any recommendations?
    BTW, is it possible that you are still running beta version of Weather State VD? o.O
    Just now, Sankotronic said:
    Hi Jim,
    Get any running Marshmallow at least.
    I am not running the Beta, I copied over the main loop when the stable came but forgot to change the name of the VD :roll:
    And just notced when you pointed it out :)
    I really doubt that they really reading anything. I send PM to one of the admins with request for help with attachment quota being full and NOTHING! At the end I had to delete half of the content posted during the last year and it took me half of the night to do that. I had to go through all my attachments and posts one by one and every time with difficult decision to delete or not but I had to make some space for this new solution.
    Maybe stupid idea, but you could use google drive of dropbox ect to host and just allow downloading and not editing...
    :-D:-D marshmallow? I like to eat them not run them :-D:-D
    Well, for this new version that is still cooking in my lab, you will probably be able to copy/paste code, but also you will have to add two buttons. Will try to make upgrade easy as much as possible and maybe make it possible to skip importing complete VD all over again.
