JohnnyC 7
After the release of the official Alexa skill for Amazon Echo, a number of us are unable to "Discover Devices" after successfully setting up the skill and connecting the Amazon account to Fibaro ID
I wanted to open a thread to specifically debug this issue, as I accept that Amazon currently only supports (officially) US, UK and EU, and I was expecting that some restriction of cloud to cloud service maybe implemented from the multiple data extraction points involved in the layers of this integration... . However a number of UK forum users have also experienced the same.
Therefore, I list the following steps I have undertaken to date without success in the hope that we can identify a fix/workaround, or simply discover that we should stop trying as it is possible that certain unsupported (officially) use cases won't allow (in the hope that this is the reasoning behind the "Custom Skill"
Hardware
- I am in New Zealand and also have a setup on a bench in Australia
- Echo devices (both "Echo" model - Not Dot) Software version 5264
- Both using HC2 on v 4.120
- I use the remote access via Fibaro ID as designed - No Port forwarding or alternative setup
With the above in mind, there are no setup configurations that are outside of what would be considered "correct" in terms of system design. The following is a list of steps i have taken to try and remedy the issue.
- Reboot everything in various order (Network, HC2, Echo )
- Remove multiple layer network structure (disconnect access points and only use router) reconnect everything from scratch including forgetting known networks
- Reduce Fibaro ID remote access to a single HC2 (rather than multiples) as the "Alexa tell/ask Fibaro to list Home Center Devices" appeared to not function
- Fresh install of Alexa app (have to use device with US iTunes account)
- Full reset (deregister AND reset button) of Echo
- Checked Discover Devices still worked with other skill - (Logitech Harmony had no issues)
To this point no success. I read in another post that a user found "alexaProhibited:true" somewhere in the REST API - I couldn't find it in mine.
Things left to investigate:
Potentially there are some port (UDP/TCP) access issues as Alexa is largely driven through outside communication
Will send this detail to support to see if the developers can let us know if it is, in fact, due to restrictions driven from the Amazon build requirement
If the above is the case, can we expect a workaround in the "Custom Skill" ?
So now we open up the floor.. Let everyone know what you have experienced and add some value to see if we can debug effectively as a community.... Keep the thread clean and relevant to the task... pages of "+1's" are annoying to work through and voicing general dissatisfaction or opinion, while valued, is not what this thread is for
23 answers to this question
