Request Tado VD
pnutp0wer
Hi everbody,
I have a Tado Thermostat and was wondering if it is possible to create a VD for this thermostat?
I found this unofficially API on the internet:
If anybody knows someone who already got a VD for Tado please let me know!
  • 4 months later...
  • 6 months later...
Also interested in Fibaro getting access to info from Tado TRVs!
Could anything be achieved via Tado connected with IFTTT as an alternative?
Tado recently updated it's IFTT applet functions. It's now possible to use the Tado's temperature as variable within IFTT. So you can let IFTT update a Fibaro variable with Tado's temperature, for example.
I must have missed the Fibaro HC2 IFTTT integration! When did that happen, how is it setup?
www.smarthome.com.au/smarthome-blog/fibaro-home-center-http-commands/
    I'm wondering if you've an example of your setup with Fibaro and Tado. Could you share some pictures?
    I am also very much interested in this. I want to connect my Todo to my HC2 already for a long time. Would be a great time, especially with the new Fibaro Heat Controller out.
    The possibilities that Tado is offering you are still very limited, as you need to create an IFTT applet for every change in temperature you'd like to monitor...
    So let's say you'd like to monitor the temperature between 15 and 25 degrees and you're fine with leading numbers (no decimals). In that case you need
    - 11 different Fibaro scene's that set your variable to the right temperature
    - 11 different HTTP commands to set your Fibaro variable to the right temperature: follow this link for help...
    - 22 different IFTT applets (a - v in my example) to lead Tado's triggers to Fibaro
    /monthly_2018_04/image.png.60eb4f36edd00c15d06ec304829dd98f.png" />
    Create a new applet and choose Tado's service:
    Then choose Webhooks as Action Service:
    That's where you paste your Fibaro's HTTP command that starts the scene, wich then sets the variable to the right temperature:
    Edited by Patriek
    Hi all.. I got the following Json request for Tado..
    In JavaScript it would be:
    var request = new XMLHttpRequest();
    request.open('GET'
            , 'https://my.tado.com/api/v2/me'
            + '?username=' + encodeURIComponent(username)
            + '&password=' + encodeURIComponent(password)
            , false);
    request.send();
    if (request.status == 200) {
        var me = JSON.parse(request.responseText);
        var myLocation = me.mobileDevices[0].location;
        var distance = myLocation.relativeDistanceFromHomeFence;
        var bearing = myLocation.bearingFromHome.degrees;
    '[0]' could be '[1]' if your mobile is not the first but the second device registered under your account
    Is there somebody able to convert to lua request or similar?
  • @Patriek Thanks for your input!
    I'm not a big fan of using IFTT. First I'm testing the Geofence feature of Tado to create a good Home and Away mode in Fibaro.
    Unfortunately the Fibaro app uses a lot of battery so maybe this is a better solution.
  • @alexpelli
    First I made a variable named: mode with the options home and away.
    IFTTT will do a HTTP command to my virtual device.
    Secondly, I made a virtual device with 2 buttons, the IFTTT http commands refer to the button ID's. the Home button uses the following lua code:
    So the first line is changing the "Mode" variable
    The second line starts scene 94, which is a push message scene to my mobile devices.
    The only thing is that I didn't port forward Fibaro to use IFTTT with it. So it's not working for me. Also I'm not sure if the way I've done it, is the right way.
    • 6 months later...
    Guest andyhud
    Any other success with this? I'd love to get Fibaro reporting temperature on the Fibaro App / Ipad app etc from the Tado Smart Thermostat (or even Tado Smart Radiator Valves)
    Cheers
    Andy
    • 1 year later...
    Hi guys, do any of you have success to control some functions of Tado from HC3?
    According this manual:
    I have done little succes to generate commands i need with curl.
    Now my problem is to translate curl commands to HC3 QA or Scene format.
    Is it possible to get any help from community to doing that?
    The commands are:
    1. first of all i need to get oauth token
    curl -s "https://auth.tado.com/oauth/token" -X POST -d client_id=tado-web-app -d grant_type=password -d scope=home.user -d username="[email protected]" -d password="YourTadoPassword" -d client_secret=wZaXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX | perl -pe 's/^.*"access_token"\s*:\s*"([^"]*).*/$1/' > the_result_will_go_in_to_variable
    2. after i get authorisation token in to variable, i can use it to actually control Tado devices, in this example i want to put home into AWAY mode.
    curl -s
    -X PUT -H "Authorization: Bearer here_must_be_variable_from_step_1" -H "Content-Type: application/json;charset=utf-8" --data '{"homePresence":"AWAY"}'
