Using a Google Home (or any Chromecast device) to ear (text to speech) messages from Home Center
If you want to generate an audio message from a scene or virtual device and ear it on a Google Home or a Chromcast device, just do this:
  • configure a server (e.g.: a Raspberry PI) with the following software:
  • add a global variable in Home Center
  • create a simple Home Center scene activated by the variable
And then simply put a text string into the variable and ear it play on the audio device.
Expect between 3 to 6 seconds between the variable setting and the audio to play (depending on the various devices involved).
Link to post
  • 2 months later...
Hi
Could you elaborate on this?
I've installed google-home-notifier successfully on my raspberry pi, but I can't get it to work with the example.js and I have no idea how to call it from my Home Centre!
Link to post
  • 1 month later...
  • On 28/7/2017 at 2:41 PM, qedes said:
    Hi
    In order to call the notifier I use this Lua scene triggered by a global variable (change the URL according to your configuration):
    Link to post
    • 3 months later...
    local url = "http://10.0.0.17:8080/google-home-notifier?text="..message:urlEncode() local http = net.HTTPClient()
    @ilcato this is exactly the LUA scene i have been looking for.  im curious know if this can be broadcasted onto more than just one google home (multiple) and also you mentioned that you must      "(change the URL according to your configuration)." are you implying that i must enter the IP address's of each google home i want the TTS broadcasted to?  im still quite new to LUA scenes..
    Thanks,
    Matt
    Link to post
    Thanks,
    Matt
    The URL is the one of your google-home-notifier server. From there you can send messages to all your devices.
    Link to post
    @ilcato ive repurposed my Raspberry pi i had used for my ha-bridge.  Im running into some issues how install the first steps concerning the NPM install  "$ npm install google-home-notifier"
    Im very familiar when using the raspberry pi command lines, but ive never used NPM before.  you'd you mind telling how you went about setting up the first part of the google listener concerning NPM?
    Thanks in advance!
    Matt
    Link to post
    Thanks in advance!
    Matt
    What's the log of your command?
    Link to post
    i kept getting a few different errors, so i just wiped the micro-SD and started over with new image of raspbian..  less chance of an error popping up later during the install process.
    Link to post
    I also tried installing it on a raspberry pi 2.
    I got it working doing the following steps (trying to use npm/nodejs from debian packages was not working):
    1.) Getting latest version of nodejs (version 8) from here:
     (version 9 is not working)
    2.) Unpack it and copy bin/* to /usr/local/bin
    3.) sudo apt-get install git-core libnss-mdns libavahi-compat-libdnssd-dev
    4.)  (as described here
    git clone
    cd
    npm install
    5.) Patch google-home-notifier/node_modules/mdns/lib/browser.js
    6.) I needed to run "npm rebuild" (but maybe because of all the tests before)
    7.) npm install google-home-notifier
    8.) Modify example.js
    This all worked perfect (hopefully, I am not at home right now and don't if there was any output...)
    Link to post
    @Alex thanks for break down! this is exactly what i was looking for. the install directions on the github and also on the npm page, for me were a bit vague and ive also never installed a donejs or used npm prior to this..
    Link to post
    @Alex do you have both running on the same RPi3? I have a Mac Mini that runs 24/7, but I hopefully can keep it dependent from the Google notifier... Also one last question. Is there anything special that I need to do if it restarts? I guess my question is if they are set to automatically start both services on boot or is there any special lines of code ill need?
    Link to post
    What do you mean with both? The google-home-notifier and ?
    For the restart: I did just add the command line to /etc/rc.local so that is starts after every reboot.
    Link to post
    im running to some problems here. included the terminal log from the install and i was able to find the folder with with all the files the node.js installed, but i cant figure out which of the files i need to edit.. any help would be great.
    Last login: Mon Dec 18 18:42:39 on ttys001
    Matthews-Mac-mini:~ TanousFamily$ open afp://192.168.0.33
    Matthews-Mac-mini:~ TanousFamily$ npm install google-home-notifier
    > [email protected] install /Users/TanousFamily/node_modules/mdns
    > node-gyp rebuild
      CXX(target) Release/obj.target/dns_sd_bindings/src/dns_sd.o
      CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_browse.o
      CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_enumerate_domains.o
      CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_get_addr_info.o
      CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_process_result.o
      CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_ref.o
      CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_ref_deallocate.o
      CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_ref_sock_fd.o
      CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_register.o
      CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_resolve.o
      CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_update_record.o
      CXX(target) Release/obj.target/dns_sd_bindings/src/mdns_utils.o
      CXX(target) Release/obj.target/dns_sd_bindings/src/network_interface.o
      CXX(target) Release/obj.target/dns_sd_bindings/src/socket_watcher.o
      CXX(target) Release/obj.target/dns_sd_bindings/src/txt_record_ref.o
      CXX(target) Release/obj.target/dns_sd_bindings/src/txt_record_create.o
      CXX(target) Release/obj.target/dns_sd_bindings/src/txt_record_deallocate.o
      CXX(target) Release/obj.target/dns_sd_bindings/src/txt_record_set_value.o
      CXX(target) Release/obj.target/dns_sd_bindings/src/txt_record_get_length.o
      CXX(target) Release/obj.target/dns_sd_bindings/src/txt_record_buffer_to_object.o
      SOLINK_MODULE(target) Release/dns_sd_bindings.node
    > [email protected] postinstall /Users/TanousFamily/node_modules/ngrok
    > node ./postinstall.js
    ngrok - downloading binary
    ngrok - downloading progress: 5350881/5350881
    ngrok - binary downloaded to /Users/TanousFamily/.ngrok/aHR0cHM6Ly9iaW4uZXF1aW5veC5pby9jLzRWbUR6QTdpYUhiL25ncm9rLXN0YWJsZS1kYXJ3aW4tYW1kNjQuemlw.zip
    ngrok - unpacking binary
    ngrok - binary unpacked to /Users/TanousFamily/node_modules/ngrok/bin/ngrok
    npm WARN saveError ENOENT: no such file or directory, open '/Users/TanousFamily/package.json'
    npm notice created a lockfile as package-lock.json. You should commit this file.
    npm WARN enoent ENOENT: no such file or directory, open '/Users/TanousFamily/package.json'
    npm WARN TanousFamily No description
    npm WARN TanousFamily No repository field.
    npm WARN TanousFamily No README data
    npm WARN TanousFamily No license field.
    + [email protected]
    added 138 packages in 43.097s
    Matthews-Mac-mini:~ TanousFamily$ var googlehome = require('google-home-notifier')
    -bash: syntax error near unexpectedMatMatMatthewMatthMatthews-MacMattMatthewsMatMattheMaMattMatthewMaMattMaMMMaMMMMMMatthews-Mac-mini:~ TanousFamily$
    Link to post
    Edit example.js or make a copy of it and edit this copy (IP/URL, language).
    Run this file (e.g. : node example.js)
    This part you actually don't need:
    Just use the scene-code posted at the beginning.
    You can also test your setup by calling your raspberry pi with this URL ("node <js.file>" must be running at this time at your rasppi):
     curl -X POST -d "text=Hallo Google Home" http://<IP OF YOUR RASPPI>:8091/google-home-notifier
    Link to post
