Dave_H 52
Like many others here, I'm frequently plagued by periodic crashes and 503 errors. In my case, I noticed that the memory usage would increase dramatically, to the point where scenes would no longer run, and the web interface wouldn't respond. Only a restart would fix it. I traced it to what I can only think is a memory leak, and I have a suspicion that it's related to the Heating/Cooling Panels. It might be fine for a while, and then for a week or so, I'll get the memory leak problem occur again. I can't be 100% sure, but I'm coming to conclusion that this happens after I've updated the Heating Panel.
So I wrote this scene to monitor the memory usage and to automatically reboot the HC2 if the usage exceeds a specified value. I also have it writing the memory usage values off to AllThingsTalk, so that I can see the history, like this:
For more details of AllThingsTalk, then see this post:
Disclaimer: Only use this scene if your system is generally stable but occasionally has a memory problem, otherwise you might send your system into a continuous reboot loop. Please use this scene at your own risk. Only use it if you know what you are doing.
Memory Monitor.lua
If you don't want to mess around with setting up AllThingsTalk, then here is a second version without this functionality:
The scene is triggered every 5 minutes by a global variable. See
orPlease login or register to see this link.
for examples of how use a timer global variable.The scene is currently set to reboot when the memory usage exceeds 70%. There is still the possibility that if the memory usage is increasing at a very high rate, then the HC2 will crash before the scene next runs. So setting it to 70% seems to be low enough to catch most instances. Do not set this to a low value otherwise your HC2 might go into a continuous reboot loop. Take a look at your normal RAM usage in the Diagnostics Panel and use a value higher than this.
You will need to change the line of code that specifies the Mobile Device Id which should receive the notification message when the memory limit is exceeded. You can find the device id from the API. Enter the following URL into a browser:
This will return a list of the mobile devices and you can select the appropriate one.
You'll also need to assign the correct values to the AllThingsTalk ClientID, ClientKey and AssetId if you're using the first version of the scene. You can get all these values from the Maker pages of AllThingsTalk.com.
0 answers to this question
