Hi,   Hopefully this will be replaced in a few months with direct control of Sonos from Alexa through a native skill supplied by Sonos themselves In the meantime if you are using the http-api and have the HA bridge running then this may provide a stop gap for you if you require one   This compilation builds on work from a number of people including @morpheus75, @lennypenny, @matt1981 and others.   This solution has two parts and both will be needed for each zon
