Single/Doubl Relay Switch vs Single/Double Switch 2
Bogdan Munteanu
Guest spazpeker
with the original switches you could switch a separate supply to the outputs  which could be a different voltage ac or dc
it was z-wave and did not monitor current
with the switch 2 the outputs are powered from the supply input
they are z-wave plus and they monitor the supply current
you can also use it for z-wave diagnostics
it is slightly bigger
it has bigger terminals allowing more than two wires per terminal
