Roller Shutter and 433MHz
Jaapdeknaap
Hi All,
I bought a beamer elevator and it comes with a 433 MHz module.
I would like to keep this also installed in combination with a Fibaro roller shutter 2.
Now i don't know on witch side i must put the roller shutter, on the side of the beamer or the side of the wallplug?
The 433 MHz is only for backup when fibaro loses contact, and i don't want to complete remove the ceiling.
Thank you very much in advance.
David
Edited by Jaapdeknaap
5 answers to this question
You can connect it as I have shown it in the picture.
But I'm not sure, but I think the COM must also be on the L.
Edited by Reinhold
Id say common will be internally linked inside the controller to neutral.
Edited by Jamie mccrostie
