Dear All,
I get a question - can I connect DS sensors as shown on below picture with using USB?
Problem is that I get only 2 wires from sensor location to place where I can get UBS device.
BR
PBr
You should do like this and not as your picture.
Guest spazpeker
If you only have 2 wires you can
wire 1 0v connected to pcb and pin 1 of the sensors
wire 2 connected to pcb TD and pin 2 of the sensors
localy to the sensors a separate DC PSU 3v - 5.5v  connected to
pin 1 0v
pin 3 3-5.5v DC
