Alpha 0
Got my camera working (Foscam C1), but the small jpg preview image in the web interface doesn't work. It does work in the app though. If I examine the URL HC2 is using to display the image it seems to add "?ts=xxx" at the end. That doesn't work well with the camera which doesn't expect two question marks in the url. The numbers behind seem to be some kind of serial number. If I remove that part the image displays. What is HC2 doing here?
