smolson00 1
Hi All,
This is my first post so bear with me.
Im currently installing my first Fibaro system. I have wired a momentary push button switch to a dimmer 2 as per the instructions. i.e. sx to the switch and s1 from the switch. It works perfectly from the computer and app. It doesn't work as expected from the switch. i.e. i press and hold to dim and a quick push to turn on/off and it doesn't do anything.
Is there something i need to do in the settings for the 'dimmer 2
I am a bit lost
Regards
Sean'
Edited by smolson00Link to comment
1 answer to this question
