Get IP Address from MAC Address
eureka
Say that I know the MAC address of a specific device I have and I want to retreive the IP Address. How can I retreive it using LUA?
  • Answers 46
  • Created
  • Last Reply
Hi @eureka
There is basic arp functionality that you may be able to leverage
You'll find some info here
Hope it helps
_f
  • Thanks! Maybe you can help me a bit.. I was trying to get a list of all mac addresses in lua. From there I want to get to the IP of those mac addresses.
    I wrote the script below (using
    ) but most of the time I only get one MAC address while, when I look in my router, I see way more. I'm still learning but shouldn't this loop through a json which contains all mac addresses and return the mac addresses as i increases?
    What am I doing wrong?
    @eureka
    I'm away from home at the moment so I can't test but try leaving out the two places you are using local to declare a variable so just use
    response, error.......etc
    JsonTable  =
    You may be testing the variable at each loop ....
  • Do you mean like this? If so, I tried it but it doesn't work. Must say that sometime I get 1 mac address and sometimes 2 mac addresses on the same timestamp...
    You might think that the code posted above looks up IP addresses, but it does not. That code shows "ephemeral data". It only shows a MAC-IP pair if there has been some form of communication between a device and the Home Center, so a HC cannot detect the IP of device X if X is not communicating with it. Second problem: after some time (maybe 10 minutes, I do not know, but it is certainly limited and it is not very long) if there is no more communication, the entry is removed from the arp table.
    I do not have a better solution. A fixed IP? But of course, you knew that already and you would not have asked this question if you could assign a fixed IP to your device.
    Can you write code on the device? So that the device, for example, starts a scene on your HC?
    Edited by petergebruers
  • ok, so only way to go is to force homecenter to try and connect to a device through IP, no?
    Edited by eureka
    Could work. Let us assume your DHCP range is IP 100 - 120 so your device will be in that range. Write a script that opens a connection to those addresses (for instance, loop over all IP and start a http connection. It is not important to have a real connection.). This can be done in less than 10 minutes. Then, use the API to dump the arp table and you will have a snapshot of all available IP and MAC...
  • wow! that is actually quite the idea... I'll try it when I get home. Will keep you guys updated on whether it works or not.
  • tried it out with following code:
    If I look in debug I see it takes approx 3 sec to get 1 address. with 255 addresses it takes approx 13 minutes.. which might be to long. Any idea on how to speed this up?
    I think the 55000 is the timeout in ms. Please try 5000 or 1000. Or split the range in two and run 2 vd in parallel? Never tried that but I think it sounds good on paper...
  • 55000 is the port. How can you split range in 2? Lua runs line by line right? Or do you mean making a seperate scene?
    @eureka
    Yes . You could try 2 running at the save time but I'm not sure how many socket connections the hc2 can have open at one time... if it is more than 2 you could run 4 vd/scenes at the same time but I wouldn't run more than that.
    Another approach could be split up your home network. For instance I have a mine set up as follows
    Ip 1 - 8 gateway and admin
    9 - 140 static ( most of my devices have static ip setup)
    141 - 255 dynamic ( any visitors get assigned here)
    So depending on which category the device you are looking up belongs to you have IP's to search
    A vd main loop executes every 3 seconds but within that single loop you can check multiple network devices.
    I have a network monitor (see wwwapi monitor in my signature)  that uses the same approch as you're using to determine  online/offline status.
    I check 6 devices with a 250ms delay and it works without issue so you should be able to speed up your search.
    Could I ask why you want the MAC for ?
    Edited by AutoFrank
  • With VD main loop you mean the for loop, am I correct?
    How would I set it up if I wanted to check multiple ip's in 1 loop? Surely not by putting in all ip addresses by hand?
    @eureka
    No.. the main loop I mentioned was referring to the code in the virtual device that get run continuously. If you create a new vd it will be the only place you can write code. ( if you add labels or buttons later, these give you other places to add code )
    This is one of the main differences between a virtual device and a scene. A scene is run on demand where as any code in a virtual device main loop is executed continuously . I'm sorry I can send you a screenshot as I'm not at home and working off my phone.
    If you do something like
    While i < 255 do ...
    -- add your code to check
    The code in the "while loop"  will execute within one virtual device main loop cycle so it should run 255 checks. You won't be able to run this at full speed ( ie as fast as the code can run) as you will need to allow time for the socket connection to be made and receive back a response and close the connection before the next check.
     I have ran thus with a 100ms delay but in my code I use a 250ms delay. This should allow you to check all 255 ip  in about a minute.
    Make sense ?
  • Yes, makes sense but that's what I am already doing. I made a Virtual Device and pasted the for loop in there. However, every iteration of the for loop takes 3 seconds.
     Yes. kind of .. but you are relying on the main loop to iterate through your ip addresses
    If you were to use while loop then the iteration is within the while loop
    Something like this might work ...
    Edited by AutoFrank
  • I managed to fix the ip addresses of the devices I want to check (which is considerably less then 255). I put those devices in an array. Now looping through the array with the While loop. It now executes 2 ip's in 1 second but then waits 3 seconds and does the last IP. waits 3 seconds and does the first 2 ip's... In principle I can live with that, however, I would like to solve the issue to understand why this behaviour is still happening. I would expect it to loop through the current code in the main loop of VD before another instance of the main loop is executed.
    I'm not at home and my memory is slow... I am pretty certain the http client in scenes has configurable timeout, maybe not the VD client. Maybe you can find some useful example if you search httpclient.
    Regarding "while" in a VD main loop, you cannot initialize the variable like "counter =1" because that will happen each time the loop runs. If I remember well, you can do this: "if not counter then counter = 1 end". The first time, counter is nil so the if statement sets it to one. The next run, the if statement does not alter the counter. I think...
    I can work on this tomorrow if this does lot help.
  • Why is it not possible to set i=1? As I understand code, a while loop only loops through the part between while and end. If the i=1 is defined before that, it will not reset to that value. Only when the main loop restarts will it go back to i=1 which should not be a problem because it should redo the whole script right?
    I'm using a mobile phone so I my explanation may be a bit terse...
    The main loop code runs every three seconds. So, if you could do one IP address each run that might work.
    In pseudo code it would be like this:
    If counter does not exist, counter is 1
    If counter is 255 then counter is 1
    Test IP address at "counter"
    Counter = counter + 1
    This wil run forever. You might have to pauze after going from 256 to 1. I am sorry, I am thinking out loud.
    The test should take less than 3 seconds, and that piece of the puzzle is still missing.
    There is no "while" in my pseudo code!
    Also, to make it robust, the test must not throw an error, because an error kills the main loop. I guess you need "pcall" to wrap the http call (please use search of this forum to find pcall examples)
    Does it have to be a VD? I would try a scene instead, because of the configurable time-out.
    Also please have a look at topics by @AutoFrank
    Edit: changed maximum counter from 256 to 255 so it tests only from 1 to 254, because 255 is very likely to be a broadcast address. You do not want to send data to a broadcast address.
    Remove broadcast address from loop
