[Feature request][Mobile apps][Cloud] Push notification when HC/HC2 cannot be reached
qnstie
I would like to request the following functionality (this applies probably mainly to the Fibaro Cloud, but should manifest itself mainly in a mobile app).
The problem:
AFAIK there is no way to be notified if the HC/HC2 is no longer available in the internet.
And this is very important, because this can mean a number of bad things:
1. The power is down
2. The internet connection is lost
3. There is a burglary and someone disabled the system
4. Many more...
The solution:
Fibaro Cloud servers should be able to provide (probably upon request) a simple monitoring functionality of the HC/HC2 centrals (simple "is alive?" call, probably invoked by the HC/HC2).
If the "is alives" are repeatedly not received (some simple rules decreasing the rate of false notifications couldapply), the user (administrator?) should get a push notification and optionally an email.
Thanks in advance!
  • 4 weeks later...
The problem:
4. Many more...
The solution:
Thanks in advance!
+1
+1 from me.
+20 from CZ/SK dealers :>.
Maybe one addition since PING not telling anything.
- check if Z-Wave and BUI is runnung (BUI not giving 503, BUI is not stucked).
