Mo19 1
Hi guys,
I have the followin problem - when i updated the HC2 to the newest beta version (4.134) all my Remotec with firmware version of 1.0 and even those of 1.2 have stoped working. It seem that they are using the template as the ones i have with firmware 1.8, but i tried to remove and add them and got no luck with the codes i thought they were using for controling Daikin AC units in the apartment. The main problem is that there is no info on the web about the code list for versions 1.0. I've tried so many configuration of codes - nothing. I tried with and without soft reconfiguring after the code is changed - nothing.. Even tried without using the template and manualy write the parameters and their values - nothin... the device blinks and nothing happens.... Remotec can not be updated to the last firmware via USB, so it becomes useless device for me....Now what? Any suggestions?
4 answers to this question
