Door sensor as 2-input device
tnesheim
The Fibaro door sensor have one dedicated external input (which also is connected in parallell with the reed switch). There is also another "input", the tamper switch. I do not need this feature and wonder if I can "rebuild" my sensor using the tamper input for a reed switch. Doing so will make the door sensor a two input device, I hope, both inputs able to trig their respective scenes.
There might be some problems doing this..will the tamper-alarm mask/disable signals from the ordinary input? So, have anybody tried this?
