FGS-222, newer version
Jasperwaale
I have looked online for videos and other info, but I cant get this to work,   and appreciate if somebody are able to offer some advise or help
We in Vietnam and I have a 2 x on/off contact switch not much point showing the photos as local cables are all same Red,
Layout is not as the videos I found  but N L IN Q1 Q2 S2 S1
Live I found going to each of the 2 switch and Neutral is a bundle,   so Bring in Neutral from the bundle using my Wago clips, move switch output to S1 and S2
take to light cables and put to Q1 and Q2  and the Live (  hot from test pen ) to L  and IN and One side of both switch,
Just do not work  Im able to tune on and off lights using the both of switch, but I cant include the Relay so cant do the Setup
Videos I found are ll it looks of different relay or wall sockets not on and off switch,
Any Ideas ?
On pic you got FGS222, on movie is FGS223
Manual your version
Manual for new version
    Well the Manual you link to have Ports on other order are you sure ?  have a look at my photo and the one in the install manual
    You don't have the version 2 (so the first link of A.Socha you should get):
    The terminals on the photo and their order is like in FGS-222:
  • Right that kind of makes some sense, expect for that done work for me, I need to get one more module to test and see if module is to blame
    So this is correct then
    Move switch output to S1 and S2
    Edited by Jasperwaale
