POPP Z-RAIN
ste73
Hello. I’ve a POPP Z-RAIN in my HCL and cannot have a good settimo for it
i mean: i would like it to switch off a plug if it rains more than X mm and turn on it after 1 Hours if it stops.
i have my scenes and thay seems to work, but ...
1) if rain is under 10 turn on cause a continuos action ... each hour.
2) if it rains i have different value from this device: mm/h but sometimes m3. So it seams that unit changes, but i don’t understand why.
any idea?
tks
7 answers to this question
Hello @ste73,
Could you show us what API presents about this device?
Open:
for example:
You can copy the content of it here or you can post it on some
 website so that you can include only a link here.
Edited by I.Srodka
  • Please login or register to see this code.
    What is strange is the change of unit. Now it’s on mm3
    Edited by I.Srodka
    I also have the same problem.
    Z-Rain meter showing results randomly than in m3 than in mm/h.
    Hi @ste73,
    To manage it like you proposed, you need to configure associations properly:
    You can associate WallPlug, so that it will turn off the wallplug every time there is a rain.
    Nadal nic. Nikt nie może rozwiązać problemu z Z-Rain? Te losowe zmiany jednostek. Brak przeglądu historii opadów. Nie jest to ciekawe.
    Wykorzystując POPP-Z rain stworzyłem scenę, która informuje mnie o ilości opadów na iPhona.
    %% properties
    643 value
    %% weather
    %% events
    %% globals
    local rainRate = 643    -- sensor deszczu chwilowy mm/h
    local rainMeter = 644   -- sensor deszczu sumaryczny m3
    local iPhone = 687      -- iPhone Radek
    local opadChwilowy
    ---- nie edytuj poniżej tej linii -------------------------------------------
    local startSource = fibaro:getSourceTrigger()
    fibaro:debug("uruchamiam scenę nr "..fibaro:countScenes())
    if ( (fibaro:countScenes() > 1) )
      -- sprawdzenie czy nie jest za dużo instancji scen
      then
        fibaro:debug("-------------------")
        fibaro:debug("scena numer: "..fibaro:countScenes().." Za dużo scen - zamykam")
        fibaro:abort()
    fibaro:sleep(2000);
    fibaro:debug("aktualny rainRate " .. fibaro:getValue(rainRate, "value") .."mm/h")
    fibaro:debug("scena numer: "..fibaro:countScenes())
    fibaro:debug("ooooooooooooooooooooooooooo")
    -- obliczanie ilości opadu chwilowego
    opadChwilowy = fibaro:getValue(rainRate, "value") - fibaro:getGlobal("opadChwilowyPoprz")
    fibaro:debug("Opad chwilowy: " .. opadChwilowy .."mm/h")
    -- sprawdzanie ilości opadu chwilowego
      if ((opadChwilowy > 0) and (opadChwilowy <= 2.5))
      then
         -- LEKKI DESZCZ --
         fibaro:call(iPhone, "sendDefinedPushNotification", "25")
         fibaro:debug("lekki deszcz " .. opadChwilowy .."mm/h")
         fibaro:setGlobal("opadChwilowyPoprz", fibaro:getValue(rainRate, "value")) -- zapisz zmienną globalną
         fibaro:sleep(1000);
         fibaro:abort()
      elseif ((opadChwilowy > 2.5) and (opadChwilowy <= 7.5))
          then
             -- UMIARKOWANY DESZCZ --
             --fibaro:startScene(163)
             fibaro:call(iPhone, "sendDefinedPushNotification", "26")
             fibaro:debug("umiarkowany deszcz " .. opadChwilowy .."mm/h")
             fibaro:sleep(1000);
             fibaro:abort()
          elseif ((opadChwilowy > 7.5) and (opadChwilowy <= 25))
              then
                 -- ULEWNY DESZCZ --
                 fibaro:call(iPhone, "sendDefinedPushNotification", "27")
                 fibaro:debug("ulewny deszcz " .. opadChwilowy .."mm/h")
                 fibaro:sleep(1000);
                 fibaro:abort()
              elseif (opadChwilowy > 25)
                  then
                     -- OBERWANIE CHMURY --
                     fibaro:call(iPhone, "sendDefinedPushNotification", "32")
                     fibaro:debug("oberwanie chmury " .. opadChwilowy .."mm/h")
                     fibaro:sleep(1000);
                     fibaro:abort()
                  elseif (opadChwilowy <= 0)
                      then
                         -- BEZ DESZCZU --
                         fibaro:debug("bez deszczu".. opadChwilowy.. "mm/h")
                         fibaro:setGlobal("opadChwilowyPoprz", (fibaro:getValue(rainMeter, "value") * 1000 )) -- zapisz zmienną globalną
                         fibaro:sleep(1000);
                         fibaro:abort()
    Scena działa w zasadzie poprawnie... ale "Max. liczba instancji:" musiałem nastawić na 1 gdyż urządzenie w przypadku rozpoczęcia opadów z 0 deszczu na >0 wysyła ramkę asocjacji, z którą nie mogę sobie poradzić, tj. gdy zaczyna padać to z 0 pomiarów pojawia się wielokrotność 7.00 przy każdorazowym przechyleniu miarki na deszcz w urządzeniu (w jednym okresie 5minutowym: jedno przechylenie: 7.00 i następnie 0.5 mm deszczu...      dwa przechylenia: 14.00 i 1 mm deszczu... itd.).
    Należy również zadeklarować zmienną globalną w której zapisany jest poprzedni stan opadu w celu obliczenia ile napadało od poprzedniego pomiaru
    Edited by RADSON
    Stworzyłem również scenę wykorzystującą POPP Z rain do pomiarów opadów dobowych i włączających lub nie podlewanie ogrodu. Pomiar codziennie o 23:00
    %% autostart
    %% properties
    %% weather
    %% events
    %% globals
    local sourceTrigger = fibaro:getSourceTrigger();
    function tempFunc()
    local currentDate = os.date("*t");
    fibaro:debug("started...")
    fibaro:debug("Ilość opadów (godz. 23:00 wczoraj) = " .. fibaro:getGlobal("opadPoczatek") .. " m3")
    fibaro:debug("Ilość opadów (od 23:00 do teraz) = " .. fibaro:getValue(644, "value") - fibaro:getGlobal("opadPoczatek") .. " m3")
    ----------- sprawdzanie stanu opadów o 23:00 -----------------
    -----------   dane potrzebne następnego dnia  -----------------
    if (string.format("%02d", currentDate.hour) .. ":" .. string.format("%02d", currentDate.min) == "23:00")
    then
        fibaro:setGlobal("opadPoczatek", fibaro:getValue(644, "value"))
        fibaro:debug("Ilość opadów o godz: " .. (string.format("%02d", currentDate.hour) .. ":" .. string.format("%02d", currentDate.min) .. " = " .. fibaro:getGlobal("opadPoczatek") .. "m3"));
    ----------- sprawdzanie stanu opadów o 22:59 -----------------
    if (string.format("%02d", currentDate.hour) .. ":" .. string.format("%02d", currentDate.min) == "22:59")
    then
        fibaro:setGlobal("opadKoniec", fibaro:getValue(644, "value"))
        fibaro:debug("Ilość opadów o godz: " .. (string.format("%02d", currentDate.hour) .. ":" .. string.format("%02d", currentDate.min) .. " = " .. fibaro:getGlobal("opadKoniec") .. "m3"));
        local iloscOpadu = fibaro:getGlobal("opadKoniec") - fibaro:getGlobal("opadPoczatek")
        fibaro:setGlobal("iloscOpadu", iloscOpadu)
        fibaro:debug("Ilość opadu ostatnie 24h = " .. iloscOpadu .. "m3")
        --- załączanie zraszania, jeśli ilość dobowa opadów mniejsza niż 0.001 ------
        if iloscOpadu < 0.001 and fibaro:getGlobal("TrybPracyZraszaczy") == "Auto"
        then
            fibaro:debug("Załączam podlewanie")
            fibaro:setGlobal("Podlewanie", "true")
            fibaro:startScene(153)
        else
            fibaro:debug("Nie załączam podlewania")
    setTimeout(tempFunc, 60*1000)
    if (sourceTrigger["type"] == "autostart") then
    tempFunc()
    else
