Global variable change not triggering scene
Vinisz
Guys,
Problem, I have code below, however, change the value of Global variable "regenover" does not trigger the scene.
I don't understand why not, someone able to help me out here ?
%% globals
regenover
local trigger = fibaro:getSourceTrigger()
local regentijd = fibaro:getGlobalValue("regenover")
if regentijd == "0" then
fibaro:call(475, "turnOn")
fibaro:call(782, "pressButton", "5");
elseif regentijd == "5" then
fibaro:call(475, "turnOff")
fibaro:call(782, "pressButton", "4");
elseif regentijd == "15" then
fibaro:call(782, "pressButton", "3");
elseif regentijd == "30" then
fibaro:call(782, "pressButton", "2");
8 answers to this question
  • 37 minutes ago, RH_Dreambox said:
    Test with
    local regentijd = tonumber(fibaro:getGlobalValue("regenover"))
    How can that have anything to do with "triggering" the scene ?
    You cant trigger scene by changing the global manually, you must do that with lua.
    but you maby already know that.
  • No, I didn't , thats strange...
    the variable is changed externallay via http post. Why doenst that work ?
    6 hours ago, Vinisz said:
    Guys,
    %% globals
    regenover
    code looks ok, you dont need the local get source trigger line.
    the only thing i would try is adding brackets around the 'if' conditions (shown in bold)...
    eg
    if (regentijd == "0") then
    fibaro:debug('regentijd is 0')
    elseif (regentijd == "5") then
    and so forth and give it a go, also adding debug commands in aswell just in case the device isnt responding at least if it prints the statement you know code is ok, again i have highlighted in bold
    thanks
    eg
    thanks
    Thanks @morpheus75 but the problem is the scene doesn't fire, not that the device is no working so @sonnyboy answer is correct, the scene does not fire when changing global variables manually, only when changed via LUA (or maybe also via blockscene)
    To my opninion, this is a design flaw..... but now I at least know "why" so I can work on a solution.
    @Vinisz, make sure you set invokescene to true. That is not documented in active rest in your unit nor in developer.fibaro.com.
