Hi All,
Hoping someone can provide some insight into this. I have a FGR-222 which I would like to connect to my Garage Roller door Motor. What I currently have is:
- Forcedoor FS 1000 door opener. Manual located
- The unit is directly connected to an AC wall socket and has no wall switch
- The manual advices to connect the wall switch to GND & PB points that are on the unit. From my understanding the wall switch will not require AC/Live wire connection. See the attached image.
Can I connect the FGR-222 to this unit? If yes, how?
Will I need to provide a Live and Neutral to the FGR-222 and  connect Q1 and Q2 to PB and GND? and not worry about S1 and S2?
Any pointers will be greatly appreciated,
Thanks in advance.
Guest spazpeker
4 hours ago, hpsn said:
Hi All,
Thanks in advance.
you cant use the roller shutter, you can use either the double or single switch 2 and configure it to auto off 1 second  and connect the output to the coil of a small relay, and the output of the relay common to GND and Normaly open to PB as per above, your garage door controller will do the rest
Edited by spazpeker
grammer
    @spazpeker Thank you. I have been scouring the Internet and found
    It seems I may be able to use the older FGS-211 mico relay which has dry contacts. So if I understand correctly, I could connect FGS-211 with its IN connected to PB and Q to GND, the FGS will have Live and Neutral connected directly to L and N.
    Would be great to get your opinion on it.
    Many Thanks
    Guest spazpeker
    Many Thanks
    Some people say that that in the event of some catastrophic failure of the module mains could get onto the relay outputs, however i do have 3 roller garage doors connected just how you have described been working fine for the last 4 years, allows you to still use the garage remote as well.
    Thank you @spazpeker . Much appreciated.
