Netatmo as weather provider
iainw
Hi, can anyone tell me whether it's possible to use the Netatmo plugin to supply the default weather info to the HC2?  I currently use the Yahoo plugin and don't seem to be able to select the Netatmo plugin for this.  I can use Netatmo ok in scenes, just not the main weather info.
Thank you,
23 minutes ago, iainw said:
Thanks @Sankotronic, The VDs for Netatmo now look for data...but pick up nothing.  The Netatmo scene looks to be running OK now but not picking data from WeatherState VD??
Hi @iainw,
Just check your settings for WeaterState VD and Netatmo scene. See my first post here for details:
I can't give you more since you haven't provide me with screenshots from debug windows or any other details.
