Guides for the Forum Read more... ×
Poradniki na Forum Read more... ×
Sign in to follow this
Zaid_Evo
Home Center 2 Failing
 My  Home Center 2 hangs once every day or a two, but today while I was creating a new scene it hanged showing me a message as illustrated in the first attachment. I restarted the HC2 many times and it works well with android and iPad Fibaro Apps but whenever I try to access it through a web browser it hangs again and keep trying to load (As in the second attachment) and system stops working even with android and iPad Fibaro Apps. Consequently, I am not able to access and modify anything in the controller anymore.
I tried to use different browsers, different computers and I restarted my network router for any probable network issue but it did not work.
Did anybody faced such a problem before?
Share this post
Link to post
6 answers to this question
Hi @Zaid_Evo,
Have you tried to do the recovery procedure?
Alternatively, you can follow this tutorial:
Share this post
Link to post
  • Hi @I.Srodka
    Thanks for this helpful video, but I'm afraid of loosing all my work on this HC2 (added devices and their adjusted parameters, virtual devices, all configured scenes...) if I tried the recovery procedure. Is there any way to back them up or keeping them after recovery procedure? :(
    Thanks in advance
    Share this post
    Link to post
    If you have a backup made at some point earlier (prior to this issue), after the recovery procedure you will be able to restore it.
    Share this post
    Link to post
    I don't actually, it is a new device and I was not aware of making backup of my work. I think I have to re-configure everything ;( .From now on I will backup it periodically.
    Thanks a lot @I.Srodka
    Share this post
    Link to post
    " to "
    Temat został przeniesiony z "
    " do "
    Share this post
    Link to post
    Today I had exactly the same issue after I make an new scene.
    Only management with apps work.
    Everything hangs as soon you connect with a computer.
    Last week I connect many new devices that are build in now, I don't want to start over with a backup.
    Maybe it's an bug in the newest software.
    BR
    Jacques
    Share this post
    Link to post
    Create an account or sign in to comment
    You need to be a member in order to leave a comment
    Create an account
    Sign up for a new account in our community. It's easy!
    Register a new account
    Sign in
    Already have an account? Sign in here.
    Sign In Now
