hi all
i have a Nest stat connected to my HC2 via the IFTTT service.
I updated my HC2 on Sunday to latest 4.140.  Since Tuesday morning i can no longer send any data to IFTTT.
the error i received is:
[DEBUG] 11:10:37:
?value1=15
[DEBUG] 11:10:50: error = Transport endpoint is already connected
i put the URL in the browser and that worked perfectly fine which leads me to conclude that the fault is with HC2.
Has anyone else experienced this and importantly any solutions??
Thanks in advance
" to "
Temat został przeniesiony z "
" do "
    issue fixed.
    looks like the way the http request is sent has been updated.
    i have updated the to the new method and it works fine.
    here is my example NEST code
    local param1 = fibaro:getGlobal("temp")
    local key = "MY KEY"
    local event = 'temp'
    local url = 'https://maker.ifttt.com/trigger/'..event..'/with/key/'..key..'?value1='..param1
    print (url)
    local http = net.HTTPClient()
      http:request(url, {
          success = function(resp)
            if resp.status == 200 then
              fibaro:debug(resp.status)
            else
    [\code]
    Edited by morpheus75
