listening of any TCP port
Hi, I`m novice in Fibaro and LUA
I have some TCP device in my network transmits a txt data to custom TCP port on HC2 if some event happens (e.g. alarm)
How I can always listen that TCP port on HC2 via LUA and start to a custom action in case the txt data appear on the port?
3 answers to this question
no dice. only via own "proxy" bridge.
HC2 can only make polling as a client and can't be as a server.
    Thank for you reply!
    what you mean?
    ok, how I can make continuously background polling of virtual device state? And in case run alarm scene...
    >>what you mean?
    [3th party software]  <===> you app (as proxy) php / jserver / etc <===> HC2 LUA scene / VDev
    so. you should write own application and (the first option) listen on GET / REST requests from FIBARO LUA scene (or VDev) or (the second option) pass result from 3th party software to LUA scene via caling LUA scene
    example for arduino esp
    Edited by 10der
