AutoFrank 372
Here is a project to create a dedicated sonos room remote using a minimote remote control.
One of my kids asked if they could have a simple remote for the sonos player in their bedroom and this is what I created
I use the sonos-http-api but I'm sure it could be adapted for the other methods to control sonos with the HC2
This is what we are creating ...
4 single press functions pre-programed
4 long press functions can be programed
Lets get started.....
The solution has two parts
A scene to interpret the button press and direct them to a VD
Both scene and the VD are included at he bottom of the post. I use the one scene to interpret two minimote remote controls so adjust as you see fit
You only need one scene even if you use multiple remotes/rooms and but you will need one VD per room
/monthly_2017_10/OfficeSonosRC.PNG.e48f194e31c1fd3b964820cec8cb1f24.PNG" />If you don't use a HomeTable, please comment out this line wherever you see it
SCENE CONFIGURATION
At the start of the scene amend with the ID of your minimote device id's to trigger the scene
Adjust the references to the target Sonos RC VD(s)
Adjust the reference (851 below) to the remote at the start of each remote block of code
And that's it for the scene.....
VD CONFIGURATION
This VD has the 4 single press functions programmed and the place to program the 4 long button presses as well
Import the VD and add the IP address and port (probably 5005) of your sonos-htti-api and name and select room accordingly
In the code for Button 1 to 4 amend the sonos player name to suit your player
Button 4 contains a table with your favorites
Amend the name in quotes in the table to match your sonos setup
The code cycles through 5 favorites but can easily be adjusted to cycle through less or more
You also need a place to store the current favorite and I use my Hometable for this by adding a entry to the respective room
Add the highlighted entry to each room you have a remote for.
Adjust the Button 4 code to match this reference
If you don't use a HomeTable contact me and I'll help you create a global to do the same thing
The final part is then to add functions to Buttons 5 to 8 that represent long presses of buttons 1-4
You don't need to if you don't want to
I created these icons - There not great and if somebody has another one I'll gladly swap out
for VD for Scene
That's it
Hopefully this will be of use to a couple of forum users,
_af
Edited by AutoFrankLink to comment
8 answers to this question
