[SOLVED]Cant view cameras on Remote Access
karanveer
Hi i can see my cameras  via the fibaro app on the Local network but unavailable to see them through the remote access. What could be the issue ? Thanks
15 answers to this question
Hi @karanveer,
Could you post more details about your setup?
Viewing cameras via web browser works fine, right? Viewing cameras on mobile app in local access also works fine?
Only remote access causes issues?
Finally, are we talking about iPhone or Android app?
  • Yes that's correct. Can't see the cameras remotely . In the house they work fine on the same network . It's on both android and iPhone
    Edited by karanveer
    Okay, thanks for the info.
    Please try to change the resolution of the camera (to a rather lower setting).
    If that doesn't help, try to change frame rate as well.
    Hi @karanveer, @I.Srodka
    I have some 3 MP cameras running full resolution and can view the cameras remotely,
    I'm running 4.140 and its the latest android app
    Reagards
    Frank
    Ok sure I'll try a lower setting on mjpeg  stream, currently it's on 1280×720. Frame rate is already 1/sec
    Reagards
    Frank
    Can you tell me what resolution you have kept it on ?
    Reagards
    Frank
    Still the same result. Changing the resolution does not affect it at all as well as frame rate. The cameras work on LAN buy not remotely has happened before to others on this forum as well but after Fibaro made some changes it started working for them. Can you please help in this too ?
    @karanveer
    Here you go
  • 19 minutes ago, AutoFrank said:
    @karanveer
    Here you go
    My settings are exactly the same and it's working over wifi inside the house but not remotely. I have another app and that works fine remotely over wifi. What gives?
    I'm on the latest software version on the Fibaro too
    do you have a static or dynamic iP address? if you have a dynamic, your only "leasing" it, meaning it will change over time.   it sounds like from what your saying, that you can access it locally, but not remotely, your having an IP address issue.  you might want to look into getting DNS a service.
    Edited by matt1981
    Edit
    Hi there, i do have a static ip and DNS on the fibaro is set to 8.8.8.8 ..  i even tried our ISP's and the same result. Wont work remotely but does work inside the house over WIFI
    Wondering about h.264 ...  that codec isn´t supported within Fibaro. How many concurrent users does the camera accept? I have serious trouble with the fibaro app opening stream ports on the cameras but not closing them correctly, which ends in bricking the cameras after a while. I help myself resetting them with a cron job, but that camera handling within fibaro definately needs a rework.
    Sebastian
    Hi @karanveer,
    Could you try to reinstall the Fibaro app while you're on the go, away from your local network and log in with your Fibaro ID credentials.
  • 43 minutes ago, I.Srodka said:
    Hi @karanveer,
    That did the trick.. it's now working remotely.  Thank you so much
