Osram Smart Plug on HUE
Bodyart
For the Philips Hue lovers there is cheap
Smart Plug, which can be easily added to Philips Hue bridge in order to make non Hue lamps controlled by Hue bridge.
I made a simple small VD based on @Sankotronic's Hue devices.
I hope someone will have use for it :-)
5 answers to this question
Once I did the same based on @Sankotronic HUE system integration.
I created nice icons for this :
/monthly_2017_08/59876c54eaead_OSRAMPLUGERRORX.png.2e03723c83587eaaf212ae7557f65fe8.png" alt="59876c54eaead_OSRAMPLUGERRORX.png.2e03723c83587eaaf212ae7557f65fe8.png" />59876c588347a_OSRAMPLUGERROR.png.f104cc409b4e3a9bcb6d4b81c326d152.png59876c5bf01be_OSRAMPLUGOFF.png.e1fb86853ddd33c5dd5cf9dbcdf49aeb.png59876c5e2fc0a_OSRAMPLUGON.png.c4c4cf1705d7c50f88523edd0128f841.png59876c6096e54_OSRAMPLUG.png.d5bd98db9b022cb614bb1c22c53968c9.png
Edited by gucio1234
Hi Bodyart, thanks for the code to switch the Osram smart plug. However I need a bit more explanation on that one, if you could be so kind as to enlighten me.
I created a VD, entered IP address and TCP port in the mask and then, what do I need to do with the code?
Put it into the main loop, or add a button and put the code there?
Then I adapt some things according to my system like: hueID of course and hueUser. But please explain the following code to me:
local hueUser = _f:getGlobal('....
Does this mean I need to save the Username to some global variable? If so, how?
Thank you so much!
  • Hi @Freebird,
    in my case i was storing HueUser in a global variable. But that is not necessary.
    Instead of the code:
    you can simply use:
    The whole code is to be placed in a VD under the "Of/Off" toggle button.
    Enjoy coding
    Thank you for your quick reply!
    I tried to find what I am doing wrong but can't find it...:
    1. I create a VD, put the IP address of the Hue bridge into the field and the TCP port 80.
    2. In advanced settings I add a button (a single one), label it and copy your code into the window and check "LUA Code".
    By the way: Is it important to check the field "primary"?
    3. I change the variable "hueID"
    4. I change the variable "hueUser" (as you said either as global variable or directly)
    5. I change the 4 variables representing the icon IDs
    6. Save the whole thing
    That should be it?
    Thank you for helping!
    When I debug the button I get:
    [DEBUG] 18:12:38: hueOn = false
    [DEBUG] 18:12:38: hueReachable = false
    [DEBUG] 18:12:42: hueOn = false
    [DEBUG] 18:12:42: hueReachable = false
    [DEBUG] 21:10:41: hueOn = true
    [DEBUG] 21:10:41: hueReachable = false
