Using normally opened (NO) radiator heads with Heat Panel
cashe
Hi, everybody!
How do I use Heating Panel linked with a relay connected with normally opened (NO) head (Danfoss TWA-K NO 088H3143, for example)?
I have to link some temperature sensor with some relay that will turn ON the heater. But in case of NO heads, it will mean valve overlapping so radiator will be cooled but not heated.
How can I change the working logic? Is it possible maybe to add some option (like as "device must be OFF while until the desired temperature will be reached") in near future firmware update?
Thanks in advance.
Edited by cashe
" to "
Temat został przeniesiony z "
" do "
