mobbie 10
Hi All,
I need some help with a single switch - I had an electrician install the switch, and its pared correctly and works fine via the software. On the physical side, I have two physical toggle switches. The one that is connected to S1 works fine. The one connected to S2 does nothing. In both cases they are wired as per the diagram within the manual, ie second L out to the L of each of the toggle switches, and then from each of the toggle switches to S1 and S2 respectively.
This is the only one I have in a two physical switch configuration, all my other ones (dimmers, single and double switches) only have single toggle switches using S1 each time - hence not sure if its just config?
Ie: Left side is house wiring, right side is Fibaro Switch
L ------ L
N ----- N
"lights" ----- Q
Switch 1 Constant -------- L (second L port on the Fibaro unit)
Switch 1 'Switch' --------- S1 (this one works perfectly :))
Switch 2 Constant ------- L (exactly the same as switch 1)
Switch 2 'Switch' -------- S2 (does nothing, when I rewired it into S1, as a test, the switch itself works fine)
Is there a configuration I need to do to make S2 act the same as S1?
The unit is a Fibaro Single Switch 2.
Mobbie
3 answers to this question
