earto 1
IP camera support on Fibaro is about to become history.
I love my HC2 but unless Fibaro implement simple "digest authentication" for IP cameras, support is about to die off.
Here's why:
Dahua
- Since early 2017, basic authentication is now disabled in Dahua firmware.
- In 2016, Dahua started signing its firmware which stops downgrades to unsigned versions.
- So there's no solution once you have newer firmware installed.
Not to mention the lack of support for RTSP, with MJPEG becoming obsolete.
Digest auth is needed just to keep existing functionality.
Beware of upgrading your IP cameras!
9 answers to this question
