FIBARO! when you fix this bug!?!
2 years....
If you disable the template, you should be able to add/set the value, but the manual is very unclear on how to to that. I have done some quick tests on my MS6 FW 1.11 and here are the results:
The size of P41 if "4d" (4 bytes). If you have never changed it, the value of this parameter is "1310976".
I have reverse engineered that value, and I came to this conclusion: the formula to calculate p 41 is:
To test that, we c
