Combine routines: Sonos, Hue, Fibaro (Thermostate)
Roland196
Dear people,
I have a little puzzle...
We have Sonos, Hue and fibaro devices and a very irregular live. Our routine for waking up is setting seperate timers for Sonos (actual wake up time), Hue (starts 10 minutes before actual waking time)  and our thermostate (danfoss via Fibaro, starts 45 minutes before actual waking time) via the native apps. We have multiple routines / scenes (per device) which we can activate to do so. For Fibaro I have multiple scenes to set a global variabele for the thermostate time and multiple scenes to actually set the temperature (depending global variabele and time).
Any suggestions how I should combine everything so I only have to acitivate1 routine? General direction would be great! I presume fibaro should be in the lead...
Thans for you help!
Kind regards,
Roland
Have a look at @Sankotronic
I'm using that scene to control the events like you describe.
  • @Bodyart thanX usefull routine! However, we need extreme flexibility since out wakeup time varies a lot (per day...). So we need to be able to input the wake up time easiliy per day...
    Hi @Roland196,
    For triggering unregular events i'm using Virtual Devises, or scenes operated (triggerred) by Button, Keyfob, or other scnene controller, i'm using also fibaro swipe and remotec ZRC-90
