[SOLVED]Fibaro wallplug -- Turn off LED indicators?
Hi. Does anyone know if it is possible to turn off the LED indicators on a FIBARO wall plug/switch/relay? I'm having trouble sleeping, and the darned lights are keeping me from it!
I'm not using the FIBARO gateway, but a RaZberry transciever.
Is there a parameter setting?
Thanks for any information!
Kind regards, Emil
5 answers to this question
Parameter 41 you can turn off the led ring.
But i don't no if you can do it with RaZberry.
Edited by Reinhold
    Tried getting it and setting it (1 byte according to the manual) in the expert ui, but didn't seem to work. Thanks for the information. I'll investigate further.
    Kind regards, Emil
    as far as i know
    for the wall plug plug, push and hold the button on the wall plug
    led will go out and stay out.
    Thanks akatar! That worked. Almost :) The LED is no longer showing a color when it is on. Do you know if it's also possible to disable the flashing of the LED when it goes on and off?
    Hi @Emil Müller!
    Try setting all three parameters: 41, 42, 43 to value 0.
