Ole 14
I manage three houses (home, work, parents house) using Fibaro Home Center (both HCL and HC2) and for controlling the panelheaters I use a lot of wall plugs. Why on earth do they keep going dead? Every month between 1-3 of them go dead. I then have to force remove from Home Center, reset the wall plug and then ad it again. This very rearly happens with any other device, but with the wall plugs, very often. Anybody have an idea why that is? It is very frustrating.
8
6
3
Mar 8
9
Dec 6
6
Dec 7
5
Nov 12
5
Ole 17 posts
petergebruers 8 posts
akatar 6 posts
I.Srodka 3 posts
Mar 8 2020
Dec 6 2017
Dec 7 2017
Nov 12 2018
Ole
Another Fibaro 102 wall plug dead at the office. Another 102 dead at home. The 101's are still stable, a few non-Fibaro wall plugs are also stable. Come on @Fibaro. This is not a coincidence. The 102'
Ole
Well, my wall plugs keep going dead for no apparent reason. The one that went dead today, I just unplugged it. I waited for a little bit and plugged it back in and it worked again. Range test result i
Ole
Two more FGWP102 dead today. When it is often enough to unplug it and plug it back in again to get it to work, that tells me that a firmware upgrade could improve the stability greatly. What do you th
59 answers to this question
