jgab 1,954
-There is always this issue with device IDs needed to be declared in the header. Then a device is reincluded and gets a new id and code breaks.
-Then there is the issue of an integer being a bad way to refer to devices when coding and thus we build hometables or declare variables.
This code is an example of trying to solve both issues. It works but is more of a concept for the moment as some more checks and more type of triggers need to be supported. (It supports value, power,sceneActivity and simple CentralSceneEvent for now)
Anyway, we have a scene that builds a "hometable", lets call it the "HomeTableBuilder". It builds the table from meta data stored in the 'Device description' field for devices (not for virtual devices, they don't have a description field and they don't trigger scenes anyway).
The format is very flexible to specify where in the home table 'tree' the deviceId should be inserted..
'Device description' = ["dev.%room.tableLamp.%id"]
will set HomeTable.dev.kitchen.tableLamp=417, if the device is in room 'kitchen' and has id 417
'Device description' = ["dev.%section.%room.tableLamp.%id"]
will set HomeTable.dev.upstairs.kitchen.tableLamp=417, if the device is in section 'upstairs' and room 'kitchen' and has id 417
'Device description' = ["dev.remote.%id"]
will set HomeTable.dev.remote=362, if the device is a fibaro remote with id 362
The code in the HomeTableBuilder that needs to be setup is:
So this take care of creating a hometable (HT in the code) from meta data stored in the devices themselves. We can then add more static configuration data to the hometable etc.
After that we declare which of our other scenes should receive events. (Test1 has id 313, and Test2 has id 316 in this example). sceneId(string) is a convenience function to get the ID from a scene name.
This says that we want to receive property.value events from "tablelamp" and send it to the scenes named "Test1" and scene named "Test2"
We declare the same for "power"
And our fibaro remote should send its events to "Test1" and "Test2" too.
The HomeTableBuilder then dynamically creates another scene in the HC2 named "EventProxy"..softwareVersion. (it's always created hidden for me!?, do "show hidden")
with the following code:
This "EventProxy" scene receive triggers for the devices declared and send them to the scene we declared having interest in these events, Test1 and Test2 in this case.
The code in a receiving scene (like Test1) then looks like below. (No declared triggers in the header, it gets all triggers from startScene from the EventProxy)
Scenes should still declare globals, weather etc... triggers that are not connected to devices IDs.
So, what have we achieved?
-We don't have to deal with numerical device IDs in our code
-We can add meta data to devices that tells where in the HomeTable they should be inserted
-We don't have to declare numerical IDs in headers
Drawback: A small performance penalty to let the EventProxy trigger other scenes instead of they being triggered directly. (Seems to be very small penalty though, logs are always on the same second in EventProxy and receiving scenes for me). One could generate different EventProxy scenes for different triggers to distribute the load a bit and ensure that the EventProxy doesn't hit the maximum 10 active instances... However, an activated EventProxy instance is very quick to dispatch the event and then terminate.
Improvement: Let scenes dynamically register which events they want when they start up. Only issue is how often the EventProxy need to be rebuilt...
Code for the complete HomeTableBuilder:
11
3
2
Dec 10
10
Dec 9
8
Aug 16
6
Dec 17
4
jgab 36 posts
jompa68 11 posts
petergebruers 3 posts
ipsofacto 2 posts
Dec 10 2017
Dec 9 2017
Aug 16 2018
Dec 17 2017
jgab
-There is always this issue with device IDs needed to be declared in the header. Then a device is reincluded and gets a new id and code breaks. -Then there is the issue of an integer being a bad
jgab
With your own sense of time (the code uses a defined osTime() instead of os.time) it is quite easy to adjust the drifting clock on the HC2 - mine is 417 secs behind at this moment. Hopefully Fibaro wi
tinman
one can emulate 'CentralSceneEvent' event trigger (but there is more, e.g. 'SceneActivationEvent', 'accessControlEvent', 'VideoGateIncomingCallEvent' ... but not yet implemented in that script below.)
56 answers to this question
