Guest FredrikKarlsson
For me, the physical appearance of the home center 2 is an issue that I think Fibaro did not consider. I don’t like tech stuff actually, and having a home center 2 displayed front and center is just not an option. I realize that the design helps sales, but I stick it in a cupboard where no one can see it, underneath a shelf. I would also not place my fuse box in the center of a room, no matter the level of fantastic visual design that went into the process of making it.
Now, running power to the home center in its central position in the house has always been a bit awkward,, and I realize that actually the power supply provided by Fibaro (4 amps at 12Volts) is actually overkill for the device. Being informed of power consumption is my thing, and it seems that the home center itself really just needs about 15W, which places it well withings the range of supplying power to it the Ethernet cable and POE+.
Has anyone tried it?
Edited by FredrikKarlssonLink to comment
13 answers to this question
