[SOLVED]Fibaro Dimmer 2 FGD-212 - Double switch setup
pelaoboyka
Hi!
I purchased a FGD-212 Dimmer 2, to install it on a double switch that controls two independent lamps:
Since I do not have a neutral cable in my switch box, I would like to know if I can output 'N' to 'Sx' from the FGD-212 module as indicated in the following diagram that I found on the internet:
Thanks for your help.
6 answers to this question
The dimmer is for dimming only one light (or two, but then the cannot be dimmed independently).
The S1/Sx connections are for the single or double switch (again to control one light).
See also the manual of the dimmer 2 module.
I am using the Dimmer 2 to control 1 Lamp with a Single Wall Switch, working fine. Is it possible to use a Dual Wall Switch and use the second Switch to remote control other devices, like a fibaro wall plug?
Edited by D4RK1
  • Thanks for your help.
    I think I will try to make it as simple as possible: I just want to control one of the two lamps (the one that is dimmable), I would like you to tell me which of the two schemes is the right one.
    Thanks!
    OPTION A:
    OPTION B:
    Edited by pelaoboyka
    Hi
    You cannot use Option A nor B. The non-dimmable light must have it's connection to L (Live) directly, not from Sx. In order to switch the non-dimmable without Fibaro unit, you need a double wall switch with two independant L connections. In that way, one switch can connect the dimmable light with Sx and the other switch control L to light directly.
  • Thanks for your help. I changed the double switch so that it has two inputs: L1 and L2. I have followed the instructions of fibaro and it´s works :D
