HC2 freezing
Andres Cadena
Good afternoon,
i have look for any similar issue reported, but nothing with the new version 4.150. My HC2 was working fine until 3 days ago, when i had to restart it after (2 months with no issues) , now it freezes every day (less than 24hrs) and i have to restart it to have all the options available.
my HCL (slave) continues working with no issues, it it only related to the HC2 (master).
regards,
Andres
3 answers to this question
Same here. Today I have 503 every hour. No changes in scenes, devices or code lately. HC2 just went from "quite stable" to useless brick. 4.150
  • Hello,
    i improved the issue (only improve as i still have 503 screens) taking out some scenes that were jumping with a lot of instances, looks like the conditional in them does not run as fast as the new instance notice. i first kept only the scenes that are initiated manually and then add the ones that are triggered by time only. i still have issues with the ones with variables or motion sensors as triggers.
    hope you can improve some how your issue.
    regards,
    Andres
    Hmm. I think this was caused by some tcp programming errors I made myself. I forgot to close tcp connections on several calls to my Heos message system.
    I could have used a log of transactions right up to the crash.
    Edited by ivhansen
