Fibaro switches contact state
jack.daniels
Is it possible to read fibaro switch's contact position S1/S2 in lua scene?
This would be cool for more smart automation.
Thanks in advance
You mean if it is turned on or off?
Easy. 67 and 68 are the IDs on the switch - change to what switch you want to use:
Contact1 = fibaro:getValue(67, "value")
Contact2 = fibaro:getValue(68, "value")
If Contact1 == "1" then
     fibaro:debug("Contact 1 is on")
else
    fibaro:debug("Contact 1 is off")
If Contact2 == "1" then
     fibaro:debug("Contact 2 is on")
else
    fibaro:debug("Contact 2 is off")
Edited by Thomasn
    I mean, the physical switch state. Is it open or closed.
    Value property is different. It tells the load status, on/off
    You mean to get the status of S1 and/or S2 is actual energised by a switch?
    Not that I that I know of. The only way to get the state is by 'synchronise' it with the load. Meaning, if S1 == energised then relais 1 (R1) = on.
    This could/should be done by setting parameter 13/14 of a Fibaro FGS-221 (double relais switch) for example:
    Parameter 13: State Change (ON / OFF) for toggle switch (Parameter no.14). Default Setting: key position change = ON or OFF
    1 - ON = switch contacts connected / OFF = switch contacts disconnected
    Parameter 14: Switch Type - momentary or toggle
    0 - Momentary Switch
    I don't know if template settings can be separated  by device or by ID. Meaning, if parameters can be different by S1-R1 and S2-R2. If so, you could set S2-R2 as actual status detection by bridging the (hardware) circuit connections S1-S2 connected coming from the switch.
    Then you can use R1 to connect the light and do not connect anything on R2 (= just for status detection in HC2).
    I didn't try this, it's just a thought I had..... ;)
    Edited by Lambik
    Added 'R2 (= just for status detection in HC2)'
    The closest you can get is by using centralSceneEvent (FGS-2x2 and FGS-2x3).
    If someone holds the button, you'll get "HeldDown" and as long as it is held nothing happens. When it's released, you get "Released", no surprise there... You'll also have to handle the other events, depending on the parameters. For FGs-2x3 see parameter 28 and 29:
    1 - Key pressed 1 time
    2 - Key pressed 2 times
    4 - Key pressed 3 times
    8 - Key Hold Down and Key Released
    But there is no way to separate the relay action from the switch status. In fact, as far as I know, there is no AC relay on the market with independent inputs.
  • Yes, this is why i have started the thread
    Would be convinient to know, the contacts state. Lets say we setting up autologhts. One grope in a room which on/off by some sensor. And when it should be always on, i just press a switch on. The scene will not switch off the lght when contacts are closed (linked)
    As for now i dont know how the relay was enabled, by s1/s2, or by assciation or by other scene
    • 3 years later...
    I am using the idea with scenes described by petergebreuers and it works fine.
    My case:
    I have a window lamp controlled by a Dimmer 2. I have a few scenes that control this dimmer over the course of the week but sometimes I want to disable these scenes and just allow manual operation of the lamp. For this purpose, I am using S2 to indicate "Automatic" versus "Manual" mode.
    S1 is connected to a momentary switch and controls normal dimmer operation.
    S2 is connected to a toggle switch where OFF shall  mean "Automatic" and On shall mean "Manual" mode.
    Parameter 20 is set to "0 - Momentary switch"
    Parameter 28 (Scene activation) is set to "1 - Functionality is activated". This sends scene id 22 if S2 is ON (hold) and 23 when S2 is OFF (release)
    The following scene captures that S2 goes from OFF to ON, which means that mode is set to "Manual" (954 is the device ID, hence my choice of variable name)
    /monthly_2021_01/Set_to_manual_mode.PNG.8e2189eac59ce957c4153f2b8910643a.PNG" />
    The following scene captures that S2 goes from ON to OFF, which means that mode is set to "Automatic"
    An example scene making use of the mode button.
    The lamp is switched on when evening falls, but only if mode is "Automatic"
    I am using this concept in our bedrooms, allowing  members of the family to easily choose if their window lamp should be controlled by the system or only by the wall switch. It eliminates the need for me to go in and change the programming as soon as they change their minds about how "automatic" their room should be. Now they can decide for themselves by flicking the switch.
