Guides for the Forum Read more... ×
Poradniki na Forum Read more... ×
cford67
Android remote login fails
I've reinstalled the app on android. Reset the logins and I still can't get remote access via the mobile network.
I can login via the web browser through Fibaro remote access page but the app never works. Why is this, can it be fixed.
The app works fine when at home on the same network.
The remote access tab is enabled
Edited by cford67
Not finished
Share this post
Link to post
11 answers to this question
Me iden... No network connection...
In my tablet it's work, in my phone not work...  whats this???
Share this post
Link to post
  • Is that both on phone signal or is one mobile network, are they both android?
    Share this post
    Link to post
    same problem here, its been a problem for some time with no anwers.
    Local access works fine, Remote access for IPAD/IPHONE works fine (though slow), access via website works fine.  But android, NO it STILL does not work!
    Share this post
    Link to post
    Hi guys!
    I've checked the remote login and our back-end works perfectly fine.
    You shouldn't have any problems, please make sure you have correctly provided login and password.
    Be aware of the double login "window". First you need to provide credentials for Fibaro ID, then your local credentials.
    Maybe the app wasn't completely removed and there were some cache/temp files left behind. Now when you open this app, it tries the old credentials.
    Please make sure that when you're disconnected from the WiFi that your mobile network data is turned on.
    Share this post
    Link to post
  • It does not work! I have reset the app, reset the user and it won't let me in eternally. As soon as I'm back on Wi-Fi with the same credentials it works.
    Cam you do something about it, your response is condescending.
    IT DOES NOT WORK
    Share this post
    Link to post
    Hello guys!
    @cford67 @mobbie @AlexVidigal
    Thank you for your patience : )
    We will investigate your particular incidents thoroughly.
    Please contact me via PM regarding this matter.
    Share this post
    Link to post
  • I've raised a support ticket as well. I tried again today following the instrutions, it let me log in over cellular once, then after I had gone back onto wifi it would not work again the next time it was cellular. It immediately reported an error.
    Share this post
    Link to post
    Hi all.  So I have spent some time on this issue with fibaro support and so far to me it seems to be an issue that only effects android If you try remote login into an account that has a lot of devices (ie seems to me to be a timeout issue enumerating all the devices)
    Can others with the issue confirm the following if you get the same experence;
    1. If you log into the app from your local network first then move to a remote network without logging out of the fibaro app it work abet slowly.
    2.  If you create a local account on the hc2 and only give it a few devices I can login and use without issue with that account whereas if you go to your admin or account with lots of devices it fails to login properly remotely and the app just loads with all the icons greyed out except settings etc.
    Is this the experence others get?
    Share this post
    Link to post
    Well after not having remote access on android (but fine on web and ios) I now have it working by changing DNS from the recommended google one back to my core router address.
    Doesn't make sense but works now for me
    Share this post
    Link to post
    Create an account or sign in to comment
    You need to be a member in order to leave a comment
    Create an account
    Sign up for a new account in our community. It's easy!
    Register a new account
    Sign in
    Already have an account? Sign in here.
    Sign In Now
